3D PrintingGeneral
Insect hexa bot problem with uploading code ! HELP !
userHead Carcaterra Albert 2015-09-24 16:02:33 5787 Views2 Replies
Hello I am having a problem with my Hexa bot ! I have the Hexa bot with the Bluno beetle v1.0 board. Every time i try and upload the pre written Arduino code it seem like its not working its been about 3 hours and it still says uploading i am not sure what is causing this problem? i check for errors but Arduino says its fine i even verified before uploading.
* Insect bot mini MKII *
* by Lumi *
* http://www.dfrobot.com *
* http://www.letsmakerobots.com *
* 2014/08/13 *
* V 0.4 *
* Sort function based on Steve's bubble sort code at: *
* http://www.hackshed.dfrobot.uk/arduino-sorti ... algorithm/ *
#include <Servo.h>
// creating the servo objects for front, rear and mid servo
Servo frontLeg;
Servo rearLeg;
Servo midLeg;
// setting the servo angle to 90° for startup
byte frontAngle = 90;
byte rearAngle = 90;
byte midAngle = 90;
// setting the delay value
byte delayWalk = 2;
byte delayTurn = 3;
// Analog sensor pins
int distanceSensor = A1;
int lightSensorLeft = A2;
int lightSensorRight = A0;
// Analog sensor reading
int sensorValue = 0;
int leftEye = 0;
int rightEye = 0;
// Values
int sensorValueLeft = 0;
int sensorValueRight = 0;
int left = 0;
int right = 0;
// Change the following value to decrease or increase the sensitivity.
// Bigger value for lower sensitivity and smaller value for highter sensitivity
int lightDifference = 60;
// Decrease the danger value when you want to INCREASE the collision trigger distance.
// Increase the danger value when you want to DECREASE the collision trigger distance
int danger = 450; // Increase this value when you want to DECREASE the collision trigger distance
// Arrays for sensor reading average calculation
int leftReadings[11];
int rightReadings[11];
// Booleans for decision
boolean lightLeft = false;
boolean lightRight = false;
// Setup function
void setup(){
// serial connection for debugging
Serial.begin(9600);
// attaching the servos to their pins
frontLeg.attach(3);
rearLeg.attach(4);
midLeg.attach(5);
// move servos to center position -> 90°
frontLeg.write(frontAngle);
rearLeg.write(rearAngle);
midLeg.write(midAngle);
delay(2000);
// Light detection and filtering
void scan()
int i;
// Take 5 readings on each sensor
for (i = 0; i < 11; i = i + 1) {
// read the value from the left and right sensor:
sensorValueLeft = analogRead(lightSensorLeft);
sensorValueRight = analogRead(lightSensorRight);
// add sensor readings of both sides to their respective array
leftReadings[i] = sensorValueLeft;
rightReadings[i] = sensorValueRight;
// calculate an average value for left and right sensor readings
How to sort and find the average value. Well, that's something you can do in perhaps 1000 ways.
An easy way is a bubble sort algorithm which sorts the 11 values for each,
the left and the right light sensor in an ascending order.
Then you simply take the middle value as the one you are working with.
This way, even if there are 2 or 3 strange readings off the scale,
like ZERO (0) or 8565 when only 1023 is possible, which you will eliminate by just taking the middle value.
This is an example for some strange readings. Maybe your sensor reads 765, 786, 2567, 0, 745, 776, 156, 23, 734, 755, 2333
Sorting the readings would result in an array like that: 0, 23, 156, 734, 745, 755, 765, 776, 786, 2333, 2567
Now, if you take the middle value of the array which is 755 you should be on the safe side, at least for this kind of application :-)
// Sorting the left light sensor values
sort(leftReadings,11);
// Un-comment the following 8 lines to serial output the sorted values and the middle value of the array
// Serial.print("Sorted Left Array: ");
// for(int i=0; i<11; i++) {
// Serial.print(leftReadings[i]);
// Serial.print(",");
// Serial.println("");
// Serial.println(leftReadings[5]);
// delay(100);
// This is the final value for the left light sensor
left = leftReadings[5];
// Serial.print("Middle Left: ");
// Serial.println(left);
// Sorting the right light sensor values
sort(rightReadings,11);
// Serial.print("Sorted Right Array: ");
// Serial.print(rightReadings[i]);
// Serial.println(rightReadings[5]);
// delay(100);
// This is the final value for the right light sensor
right = rightReadings[5];
// Serial.print("Middle Right: ");
// Serial.println(right);
// Un-comment the next 9 lines for serial output of the light sensor readings and their difference
// Serial.print ("Right: ");
// Serial.print (right);
// Serial.print (" I ");
// Serial.print ("Left: ");
// Serial.print (left);
// Serial.print ("Difference: ");
// Serial.println (left-right);
// delay (130);
// Sort the array ascending
void sort(int a[], int size) {
for(int i=0; i<(size-1); i++) {
for(int o=0; o<(size-(i+1)); o++) {
if(a[o] > a[o+1]) {
int t = a[o];
a[o] = a[o+1];
a[o+1] = t;
// Desision depending on the light values
void decision(){
// Call the scan function to provide the sensor values of the left and right light sensor
scan();
// Compare the values and make a decision according the difference value
if (left > right){
// subtract right from left value to get a value to work with
left = left-right;
// check if that previous calculated value is greater than 50
if (left > lightDifference) // I will call this "Inside IF 1" in further comments.
/* If the value is greater than 50 then turn left. Why? the 50?
Due the readings it's nearly impossible to get the exact same readings
from both sensors in at the same time. So if both sensors always have slightly different readings
the robot would just wiggle left and right without really going forward. By eliminating slight differences
and set the accepted difference to a value of 50 it's more likely that the robot
actually goes to the function forward.
lightLeft = true;
lightRight = false;
// That happens when the left value in "Inside IF 1" is lower than 50
else{
/* Is the calculated value for left lower than 50 then go forward. Why? Is that value lower than 50 then the difference
between the light on the left and right sensor are not that great. In this case it should be save to go forward.
lightLeft = true;
lightRight = true;
// That happens when left is lower than right
else if (left < right){
// subtract left from right value to get a value to work with
right = right-left;
if (right > lightDifference){ // I will call this "Inside IF 2" in further comments.
lightLeft = false;
lightRight = true;
else{
/* Is the calculated value for right lower than 50 then go forward. Why? Is that value lower than 50 then the difference
lightLeft = true;
lightRight = true;
/* That "else" happens when none of the above conditions occur and the left and right sensor shows the same readings.
This condition will probably never occur but we need it anyway.
else{
// Go forward without questions
lightLeft = true;
lightRight = true;
// Walk forward //////////////////////////////////////////////////////////
void forward(){
for (midAngle = 70; midAngle < 100; midAngle +=1){
delay(delayWalk);
for (frontAngle = 120; frontAngle > 50; frontAngle -= 1){
rearLeg.write(frontAngle);
delay(delayWalk);
for (midAngle = 100; midAngle > 70; midAngle -=1){
delay(delayWalk);
for (frontAngle = 50; frontAngle < 120; frontAngle += 1){
delay(delayWalk);
// Walk reverse //////////////////////////////////////////////////////////
void reverse(){
delay(delayWalk);
delay(delayWalk);
delay(delayWalk);
delay(delayWalk);
// Left Turn //////////////////////////////////////////////////////////
void leftTurn(){
rearLeg.write(90);
for (midAngle = 70; midAngle < 110; midAngle += 1){
delay(delayTurn);
for (frontAngle = 70; frontAngle < 110; frontAngle +=1){
delay(delayTurn);
for (rearAngle = 110; rearAngle > 70; rearAngle -=1){
delay(delayTurn);
for (midAngle = 110; midAngle > 70; midAngle -= 1){
delay(delayTurn);
for (frontAngle = 110; frontAngle > 70; frontAngle -=1){
delay(delayTurn);
for (rearAngle = 70; rearAngle < 110; rearAngle +=1){
delay(delayTurn);
// Right Turn //////////////////////////////////////////////////////////
void rightTurn(){
frontLeg.write(90);
delay(delayTurn);
delay(delayTurn);
delay(delayTurn);
delay(delayTurn);
delay(delayTurn);
delay(delayTurn);
// Stop walking
void stay(){
frontLeg.write(90);
midLeg.write(90);
rearLeg.write(90);
void loop(){
// First scan for the light
scan();
// read the IR distance sensor value
sensorValue = analogRead(distanceSensor);
// Un-comment the next 4 lines if you want to serial output the distance sensor readings
// Serial.print ("Distance: ");
// Serial.print(sensorValue);
// delay(100);
if (sensorValue < danger){
decision();
// delay (130);
else {
frontLeg.write(90);
rearLeg.write(90);
midLeg.write(90);
delay(1000);
for (byte x=0; x<5; x+=1){
reverse();
delay(300);
for (byte x=1; x<5; x+=1){
leftTurn();
delay(300);
decision();
if (lightLeft == true && lightRight == true){
forward();
// Serial.println("left = right");
delay(5);
else if (lightLeft == false && lightRight == true){
rightTurn();
// Serial.println("left < right");
delay(5);
else if (lightLeft == true && lightRight == false){
leftTurn();
// Serial.println("left > right");
delay(5);
else {
stay();
// Serial.println ("Nothing to complain");
uploading.....
sketch uses 8,018 bytes (27%) of program storage space. Maximum is 28,72 bytes.
Global variables use 274 bytes (10%) of dynamic memory, leaving 2,286 bytes for local variables. Maximum is 2,560 bytes.
i am running arduino 1.6.5 with the bot on Arduino Leonardo on COM6
2015-09-28 15:13:57 Thanks for your feedback! :) userHeadPic Leff
2015-09-25 08:43:41 Problem Solved !!!! Talk to one of the techs at dfrobot and did some basic trouble shooting.
Results: choose the target board as UNO(Tools>Board>UNO), and make sure there is no wires on I/O pin0,1(serial port) and the LINK LED was OFF.
just changed the board from Leonardo to UNO and that fixed the upload problem
userHeadPic Carcaterra Albert
