Pin out of the Display
I like to use the eDP display port on the Lattepanda Alpha 864.
Where can i find a data sheet or a pin assignment for the display port and the touch port so I can fit an LCD with a touch to these ports?
Thank you,
Gusti
Thank you,
Gusti
2019-01-04 14:07:47 BL_PWR are the power for the back light of LCD screen, you can refer to this post about the LCD screen for lattepanda.
https://www.lattepanda.com/topic-f23t17 ... edp#p26438
robert.chen
2019-01-03 21:23:13 Thanks,
Two more things:
1. What is the power on the BL_PWR? This should be connected to the back light of the LCD panel.
2. What is the part number of the two connector so i can fit a cable to the LCD panel?
Thanks,
Gusti
gusti.averbuch
Two more things:
Thanks,
Gusti
