Gravity Electrical Conductivity Sensor: not working
userHead Account cancelled 2019-04-22 11:08:50 988 Views0 Replies
How do I know if the EC sensor I am working with is damaged? The voltage values that I read in the 1413 uS/cm buffer solution is higher than the values I read in the web. In a sample code I found, it should be around 216 mV, whereas the values that I read is around 900. Thank you for answering.
