Mega Sensor Shield (DFR0165) Power
userHead Account cancelled 2016-04-07 22:43:17 3031 Views2 Replies
I have stacked two board : an Arduino Mega and a Mega Sensor Shield V2.4.
I have an external voltage regulator (5V 2.5A).
Can i provide power to the Arduino through the PWR IN of the Mega Sensor Shiel V2.4 ?
What are the specifications for this power connector ?
Thanks,
Christian
2016-04-08 16:15:50 Hi there,
Mega expansion shield's PWR_IN is the same as the one on V7 expansion shield, that is SERVO_PWR.
Check here for more info [url=
viewtopic.php?f=8&t=1869&p=8669#p8669] Topic: Power Supply for Arduino card (Motor driver+ servo ...)[/url]
userHeadPic Leff
2016-04-08 15:27:01 Hi christian.ottie ,
you can find the answer in the following link:
viewtopic.php?f=8&t=1869&p=8667#p8667
And then you can also realize some other common problems and solutions in the link .
userHeadPic Wendy.Hu
