Bluno as HID to Computer or Mobile Device
I am trying to use the Bluno board in order to modify a current open source switch (https://www.makersmakingchange.com/pro ... itch-60mm/) to make a wireless version. These switches are used by persons who have a motor disability and need to control their computer or mobile device using the accessibility settings in the OS. From what I am gathering, I believe the commercial versions are sending via HID a "Volume Up" for Mac and "Enter" for PC/ Android in order for the computer to recognize the switch. Although, I suspect you may be able to send any key press?
<br/>
I have tried uploading a variety of sketches using the Keyboard, HID-Project, and HID Buttons libraries. None of these sketches compile correctly which I think might be because the UNO board does not support Keyboard? I tried switching to a Leonardo board which also didn't compile but I know supports Keyboard. I also found an article going over the AT commands and tried the following to place the Bluno in HID mode: AT+FSM=FSM_HID_USB_COM_BLE_AT. However, I now have errors when trying to upload anything. Even a simple blink sketch.
<br/>
The error message I get:
<br/>
<br/>
I would love any help in pointing me towards any sample projects or documentation that may help with what I am trying to do. Thanks in advance!avrdude: stk500_recv(): programmer is not responding
2022-01-19 18:39:32 The Bluno AS Hid is a simple device that hides a computer or mobile device. It comes with a thin and thin casing and is small enough to fit in the palm of your hand you can check here for Satellite phones and services in Australia. The Bluno AS Hid is small and light enough to carry with you on the go. It is perfect for those who are unable to carry a laptop or tablet with them while they are out and about.
verogit890
2020-11-12 14:53:51 You also need an iOS device (7+) or Android device (4.3+) with support for ... data over a BLE connection between the Bluno and the mobile device. ... the <div> ) that are hidden and shown depending on what is happening.
laurelbailey198
2020-11-06 17:06:01 ROB0102 Cherokey 4WD Mobile Platform · ROB0117 Basic Kit for Cherokey 4WD ... Support Wireless Programming Via BLE Support Bluetooth HID Support ... Bluno - An Arduino Bluetooth 4.0 (BLE) Board x1; Android 4.3+ Devices Or IOS ... Press and hold the Boot button on Bluno and connect computer through USB.
mariyahkaitlynnmefo
