UPS HAT Raspberry Pi Zero DFR0528 How to get Firmware Version?
Hey guys,
can u tell me how to get the Firmware Version from die I2C.
I tried this.
Thanks for your help
I tried this.
But im kinda missing something.import smbus
addr=0x10 #ups i2c address
bus=smbus.SMBus(1) #i2c-1
firmware=bus.read_byte_data(addr,0x02)
vcellH=bus.read_byte_data(addr,0x03)
vcellL=bus.read_byte_data(addr,0x04)
socH=bus.read_byte_data(addr,0x05)
socL=bus.read_byte_data(addr,0x06)
capacity=(((vcellH&0x0F)<<8)+vcellL)*1.25 #capacity
electricity=((socH<<8)+socL)*0.003906 #current electric quantity percentage
print("firmware=", firmware)
print("capacity=%dmV"%capacity)
print("electricity percentage=%.2f"%electricity)
2022-01-28 22:44:38 A use of the string and its branch is filed for the offers. Paths of the https://australianwritings.net/our-services/thesis/ are implied for the shows. The team is skilful for the end for the stories for the mid of the patterns in the ambit for all usages for the offers.
sashyuki
2021-02-01 15:15:41 Of course it's wrong. 223 is 0xDF, that's should be the value in 0x01.
I suggest you use
347945801
I suggest you use
This instruction will get a list, including the data of 0x00, 0x01, 0x02 and so on list = bus.read_i2c_block_data(addr, 0x00)
print(list)
2021-01-29 18:09:05 The returnvalue is 223. Is that right ? How i interpret this then?
Ty for your help
sarnus33
Ty for your help
2021-01-29 13:48:30 There is no problem with the method you use, but I don’t know what the value you return is, and I don’t know why you think it’s wrong
347945801
