RoboticsGeneral
Touch is not working on 7” 800x480 TFT DSI Capacitive Touchscreen for Raspberry Pi (V1.0)
userHead Account cancelled 2021-02-12 16:26:03 1604 Views4 Replies
Hello everyone,
I ordered 7" 800x480 TFT DSI Capacitive Touchscreen for Raspberry Pi (V1.0) from you and I connected it to Raspberry Pi 3B. It works fine, but the touch does not work. If I need to enable any setting or install anything, please let me know. I have also check the power supply current and it is also enough.
Thank you in advance.
Best regards from Germany! :)
2022-10-25 02:57:24
Were you able to get this to work?
userHeadPic Kieran.Clifford
2021-10-30 16:14:08 This Blog was really Helpful. Thank You. https://toysruscreditcard.info userHeadPic xiviga6160
2021-10-30 05:39:43 This blog was really helpful. https://blankfaxcoversheet.run userHeadPic xiviga6160
2021-02-15 17:36:26 The Raspberry Pi Touch Display is an LCD display that connects to the The DSI display is designed to work with all models of Raspberry Pi, however early If you are not attaching the Raspberry Pi to the back of the display, take extra care when Possible rotation values are 0, 90, 180 and 270.
myaccountaccess.com
userHeadPic valeriedixon1970
