Gravity: Analog Electrical Conductivity Sensor with arduino MKR1000 (SAMD21)
userHead Account cancelled 2021-03-01 01:26:31 739 Views1 Replies
I am need to use some DFrobot sensors such as DFR0300 with arduino MKR1000 (SAMD21), the sensor code is using EEPROM and the EEPROM library is not compatible with the SAMD21.
Is there a way to connect my arduino MKR1000 to an external EEPROM so I can use the EEPROM library? what modifications do I need to do to the sensor code (for example the DFR0300 code)?.
Best Regards
2021-03-01 10:49:46 Sorry, the library of this sensor is not compatible with M0, we will make improvements in the near future. userHeadPic 347945801
