Problem calibrating TDS sensor
Hi guys,
I have a TDS sensor that is connected to Arduino mini pro, I tried to calibrate it using these steps here:
https://wiki.dfrobot.com/Gravity__Analo ... U__SEN0244
but when I type enter on the serial monitor I don't get a response, it supposed to enter the calibration mode.
I will really appreciate your help
2021-03-16 16:13:50 The command you send during calibration needs to end with "Both NL&CR"
347945801
