DFrobot relay shield V2.1 temp sensor
Im trying to get ds18b20 to work through the relay shield I was under the impression that i could simply wire to the D,Vcc,GND 0-13 pins but i get no output. is there a library interface i'm missing? if i wire straight to the arduino i get it to work, if i rewire through the shield using 5v gnd and d010 i get nothing.
2021-04-06 17:59:17 You can get the code from the wiki
https://wiki.dfrobot.com/Gravity__DS18B ... U__DFR0024
347945801
