DFR0646 Physical Dimensions
I would like to put the DFR0646 in a box. Where can I find the physicals dimensions (width, height, length, display size and holes position)?
Thank's
Thank's
2021-04-16 18:38:51 Microcontroller: ATmega32u4
Clock Speed: 16 MHz
Operating Voltage: 5V DC
Digital I/O Pins: 10
PWM Channels: 4
Analog Input Channels:5
UART: 1
I2C: 1
|Micro USB: 1
Power interfaces: 2
Flash Memory: 32 KB of which 4KB used by bootloader
SRAM: 2.5 KB
EEPROM: 1 KB
Physical Dimension: 20mm*22mm*3.8mm.
myrtlewilson19.81
Clock Speed: 16 MHz
PWM Channels: 4
UART: 1
I2C: 1
|Micro USB: 1
Power interfaces: 2
SRAM: 2.5 KB
EEPROM: 1 KB
2021-04-09 16:27:58 Digital tube size: 10.1 1.9 CM
PCB board size: 11.7 2.2 CM
Other data is not public.
347945801
