Can Huskylens learn new objects ?
userHead Gmartin 2022-05-07 16:55:54 1092 Views4 Replies
Hi !
I was wondering if we learn to huskylens 5 objects and we save the data to sd , can we add a 6th object afterwards ?
Thank you for your time in advance !
2022-12-15 18:32:37
If you’ve ever wondered if HuskyLens can learn new objects, then the answer is yes. The HuskyLens AI vision platform is designed to be a powerful yet user-friendly tool that can recognize and differentiate between objects, even if they’re new to it.
HuskyLens takes advantage of deep learning algorithms and computer vision to recognize objects it’s never seen before. This means that, as long as you present HuskyLens with enough data and examples, it’s able to recognize and differentiate between new objects.
Let’s look at a practical example. Say you’re using HuskyLens to track a certain type of object. You can teach it to recognize the object by providing it with many examples, including photos or videos of the object in different contexts, in different lighting, and from different angles. HuskyLens will then use its algorithms to recognize the object, even if it’s never seen it before.
In addition to recognizing objects, HuskyLens can also classify objects based on their properties and characteristics. For example, you can teach it to differentiate between a cat and a dog based on their size, color, and shape.
HuskyLens’s ability to recognize and classify objects means that it can be used for a wide range of applications, from simple home automation tasks to complex industrial automation tasks. It’s a powerful tool that can be used for everything from security and surveillance to robotics and machine vision.
So, to answer the original question: yes, HuskyLens can learn new objects. With its powerful deep learning algorithms and computer vision capabilities, HuskyLens can easily recognize new objects and classify them based on their characteristics. So, if you’re looking for a powerful AI vision platform that can help you automate tasks, then HuskyLens might be a roomba 670 vs 690 perfect choice.
userHeadPic Myrtlee.Pierves
2022-12-15 18:25:17
Huskies are amazing animals that are not only loyal and loving, but also incredibly intelligent. They are capable of learning a variety of tasks, from following commands to recognizing objects. But can a Husky learn new objects?
The answer is a resounding yes! In fact, Huskies are capable of learning any number of objects, including ones they have never seen before. This is thanks to their high level of intelligence and their ability to quickly learn new concepts.
When it comes to teaching a Husky to recognize new objects, it is important to remember that patience is key. Huskies, like any animal, need to be taught how to do things step by step. This means that you should take your time and break down the task into small, achievable goals. For example, if you want your Husky to learn the name of a new toy, you should start by showing it to them and saying the name of the toy. Then, you can slowly increase the difficulty of the task by adding in commands such as "fetch" or "drop".
It is also important to remember to reward your Husky when they do something correctly. This will help them to understand that they are doing the right thing and that they are being rewarded for their efforts.
Finally, it is important to remember that, although Huskies can learn new objects, they may not do so in the same way as humans. For example, if you show a Husky an object and say the word "ball", it may take them longer to comprehend the concept than it would for a human. This is because Huskies process information differently than humans do.
Overall, the answer to the roomba 670 vs 690 question "Can Huskylens learn new objects?" is a resounding yes. With patience and consistent training, you can teach your Husky to recognize a wide variety of objects. Keep in mind, however, that their learning process may differ from a human's. Investing in a Huskylens can be a great way to help your Husky to learn new objects.
2022-05-07 21:30:57
Hi Gmartin,
On the UI, we only support 5 objects. However, if you are using Arduino to communicate with it, you could use this API to store more objects into SD card. Check here for details:
https://github.com/HuskyLens/HUSKYLENSArduino/blob/master/HUSKYLENS%20Arduino%20API.md#bool-savemodeltosdcardint-filenum
Hope it helps you.
userHeadPic Angelo.Qiao
Gmartin wrote:
Hi and thank you for your answer.
If you allow me i ll change my question just a little
I was wondering if we learn to huskylens 3 objects and we save the data to sd , can we add a 4th object afterwards without  learning  the first 3 again?
Thank you for your time !
2022-05-08 11:37:47
