By jobaret
#32801
How can I translate Motor:Bit extension for Mind+ in French ?
Is there a language file like mind+V1.5.6-language-7.3 (I can try to complete it) ?
Thank you
By sivernores
#45269
When it comes to translating material, I usually look for the most precise method. All you have to do now is think about where you may go and locate a qualified translator. For instance, I previously discovered and realized that translate english to italian can provide translations in a wide range of languages. And if you require an exact translation, only professionals can assist you, and you will not be disappointed. I hope to be able to assist you.
