#33408
If I have two Maqueen cars, and one IR remote control then will both cars move when I signal with IR remote control?
Seems that since the codes of the IR remote controls are the same and the device name of the microbit is not encoded in the IR keypress, each Maqueen car in range should respond to the key from one IR remote controller?
Can you please confirm this?
#33411
Hi Jaanvi,
thank you for your contacting.
Yes, the coding is the same. So they will move at the same time.
But you can programming 2 Maqueens with different codes to realize different actions.
Such as, once key1 is pressed, No.1 Maqueen moves forward; and once key2 is pressed, No.2 Maqueen moves forward.
