dfrobot sen0264 ts01 is not working as plc analog input 4-20mA
Unread postPosted:Sat Jun 12, 2021 9:29 am
by m.kumar
Dear DFrobot,
We ordered dfrobot sen0264 ts01
but it seems not working with PLC
We are using this as a 2 wire analog input device for the plc but its not giving any mA
How to resolve this issue
Thanks & Regards
Re: dfrobot sen0264 ts01 is not working as plc analog input 4-20mA
Unread postPosted:Sat Jun 26, 2021 8:20 am
by lisacarter19794
This TS01 IR temperature sensor is a non-contact infrared thermometer designed for industrial In Stock Reward Points: 890 SKU:SEN0264 Given stable output data, this temperature sensor can exhibit a much better measurement a maximum accuracy of 0.5°C. TS01 outputs 4~20mA standard industrial current signal.
Target Card Balance Now
