By Hector
#6642
Have you looked at the connection diagram included with the documentation?
[url=http://www.dfrobot.com/index.php?route=product/product&filter_name=dfr0151&product_id=511]http://www.dfrobot.com/index.php?route=product/product&filter_name=dfr0151&product_id=511[/url]
Since the LCD is a shield you should be able to just plugin to the same pins on the LCD as the connection diagram shows for the Arduino
By rjhudak1
#6643
Thanks for the reply Hector. Part of the problem is I can't open the doc. up. I have a program that opens par files but it will not open. The other problem is that there is no where to plug this in.
By rjhudak1
#6644
Ok, I got the picture open and see how to wire it. Thanks for your help. I'am sure more questions ahead.
By rjhudak1
#6646
ok, still have a problem. If I stack my dfr2009 lcd shield on my dfr0001 dfrduino duemilanove there is no spot to attach my dfr0151 clock to it. The diagram shows using wires but I thought it was modular and would fit together. I don't have the clock hooked up yet, and my display reads
12:00:00 am
blue:0  white:0
At least I have a display, even though nothing changes.
Here's a copy of the sketch I will be using
originally written by Christian,
#include "Wire.h"
#define DS1307_I2C_ADDRESS 0x68 //set rtc
#include <LiquidCrystal.h> // initialize the library with the numbers of the interface pins
/*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  R E L A Y  P A R T  |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
/*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  S I M P L E  O N  A N D  O F F  F E A T U R E |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
const int ledPin1 =  2;          // pin number for relay 1
const int ledPin2 =  8;          // pin number for relay 2
int ledState1 = LOW;
int ledState2 = LOW;
long previousMillis1 = 0;
long previousMillis2 = 0;
long interval1 = 30000;          // interval at which to blink (milliseconds) for RELAY1
long interval2 = 50000; // interval at which to blink (milliseconds) for RELAY2
/*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  L E D  D I M M I N G  P A R T  |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
/*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  F A D E S  I N  A N D  O U T  |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
int blueramptime = 60 ;    // time for blue LEDs to dim on and off in minutes
int whiteramptime = 180 ;  // time for white LEDs to dim on and off in minutes
int bluemin = 0 ;          // minimmum dimming value of blue LEDs, range of 0-255
int bluemax = 255 ;        // maximum dimming value of blue LEDs, range of 0-255
int whitemin = 0 ;        // minimum dimming value of white LEDs, range of 0-255
int whitemax = 255 ;      // maximum dimming value of white LEDs, range of 0-255
int photoperiod = 240 ;    // amount of time array is on at full power in minutes
int ontime = 10 ;          // time of day (hour, 24h clock) to begin photoperiod fade in
int blue = 3;              // blue LEDs connected to digital pin 3 (pwm)
int white = 11;            // white LEDs connected to digital pin 11 (pwm)
int bluepercent[11] = { 0, 1, 2, 5, 8 ,12, 18, 27, 44, 80, 255 };  // this line is needed if you are using meanwell ELN60-48D
int whitepercent[11] = { 0, 1, 2, 5, 8 ,12, 18, 27, 44, 80, 255 };  // these are the values in 10% increments
//int bluepercent[11] = { 0, 26, 52, 78, 103, 128, 154, 180, 205, 230, 255 };  // this line is needed if you are using meanwell ELN60-48P
//int whitepercent[11] = { 0, 26, 52, 78, 103, 128, 154, 180, 205, 230, 255 };  // these are the values in 10% increments
// int pwm_one = 10;      // extra pwm pin for future use
// int pwm_one = 9;        // extra pwm pin for future use
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);  // changed from 12, 13, 4, 5, 6, 7
                                        //  change to free up more pwm pins but cannot plug lcd to main board
/*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  R T C  C L O C K  D S 1 3 0 7  |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
byte decToBcd(byte val)    // Convert normal decimal numbers to binary coded decimal
  return ( (val/10*16) + (val%10) );
byte bcdToDec(byte val)    // Convert binary coded decimal to normal decimal numbers
  return ( (val/16*10) + (val%16) );
// 1) Sets the date and time on the ds1307
// 2) Starts the clock
// 3) Sets hour mode to 24 hour clock
// Assumes you're passing in valid numbers
void setDateDs1307(byte second, // 0-59
byte minute, // 0-59
byte hour, // 1-23
byte dayOfWeek, // 1-7
byte dayOfMonth, // 1-28/29/30/31
byte month, // 1-12
byte year) // 0-99
  Wire.beginTransmission(DS1307_I2C_ADDRESS);
  Wire.send(0);
  Wire.send(decToBcd(second)); // 0 to bit 7 starts the clock
  Wire.send(decToBcd(minute));
  Wire.send(decToBcd(hour));  // If you want 12 hour am/pm you need to set
  // bit 6 (also need to change readDateDs1307)
  Wire.send(decToBcd(dayOfWeek));
  Wire.send(decToBcd(dayOfMonth));
  Wire.send(decToBcd(month));
  Wire.send(decToBcd(year));
  Wire.endTransmission();
// Gets the date and time from the ds1307
void getDateDs1307(byte *second,
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year)
  // Reset the register pointer
  Wire.send(0);
  Wire.requestFrom(DS1307_I2C_ADDRESS, 7);
  // A few of these need masks because certain bits are control bits
  *second = bcdToDec(Wire.receive() & 0x7f);
  *minute = bcdToDec(Wire.receive());
  *hour = bcdToDec(Wire.receive() & 0x3f); // Need to change this if 12 hour am/pm
  *dayOfWeek = bcdToDec(Wire.receive());
  *dayOfMonth = bcdToDec(Wire.receive());
  *month = bcdToDec(Wire.receive());
  *year = bcdToDec(Wire.receive());
/*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  D E F I N E  :  O N E S E C O N D |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
void onesecond() //function that runs once per second while program is running
  byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
  getDateDs1307(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month, &year);
  lcd.setCursor(0, 0);
  if(hour>0)
    if(hour<=12)
      lcd.print(hour, DEC);
    else
      lcd.print(hour-12, DEC);
  else
    lcd.print("12");
  lcd.print(":");
  if (minute < 10) {
    lcd.print("0");
  lcd.print(minute, DEC);
  lcd.print(":");
  if (second < 10) {
    lcd.print("0");
  lcd.print(second, DEC);
  if(hour<12)
    lcd.print("am");
  else
    lcd.print("pm");
  lcd.print(" ");
  delay(1000);
/*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  D E F I N E  :  R E L A Y 1 |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
void relay1()  //FUNCTION TO TURN ON AND OFF RELAY 1.
  unsigned long currentMillis = millis();
  if(currentMillis - previousMillis1 > interval1)
    previousMillis1 = currentMillis;
    if (ledState1 == LOW)
      ledState1 = HIGH;
    else
      ledState1 = LOW;
    digitalWrite(ledPin1, ledState1);
/*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  D E F I N E  :  R E L A Y 2 |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
void relay2()
  unsigned long currentMillis2 = millis();
  if(currentMillis2 - previousMillis2 > interval2)
    previousMillis2 = currentMillis2;
    if (ledState2 == LOW)
      ledState2 = HIGH;
    else
      ledState2 = LOW;
    digitalWrite(ledPin2, ledState2);
/*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  S E T U P  |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
void setup() {
  pinMode(ledPin1, OUTPUT);    // set the digital pin as output:
  pinMode(ledPin2, OUTPUT);    // set the digital pin as output:
  /*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  S E T U P - D I S P L A Y |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
  Wire.begin();
  // Change these values to what you want to set your clock to.
  // You probably only want to set your clock once and then remove
  // the setDateDs1307 call.
  second = 0;
  minute = 25;
  hour = 1;
  dayOfWeek = 3;  // Sunday is 0
  dayOfMonth = 30;
  month = 11;
  year = 11;
// setDateDs1307(second, minute, hour, dayOfWeek, dayOfMonth, month, year);
  analogWrite(blue, bluemin);
  analogWrite(white, whitemin);
  lcd.begin(16, 2); // set up the LCD's number of rows and columns:
  //  lcd.print("12:00 80.6"); // Print a message to the LCD.
  //  lcd.print(char(223));
  lcd.setCursor(0, 1);
  lcd.print("blue:");
  lcd.print(33*bluemin/85);
  lcd.setCursor(8, 1);
  lcd.print("white:");
  lcd.print(33*whitemin/85);
/*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  L O O P |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
void loop()
  onesecond();
  relay2();
  relay1();
  /*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  L O O P - D I M  F U N C T I O N |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
  int daybyminute = ((hour * 60) + minute); //converts time of day to a single value in minutes
  int bluerampup;
    if (daybyminute >= (ontime*60))
      bluerampup = (((ontime*60) + blueramptime) - daybyminute);
    else
      bluerampup = blueramptime;
  int whiterampup;
    if (daybyminute >= (ontime*60 + blueramptime))
      whiterampup = (((ontime*60) + blueramptime + whiteramptime) - daybyminute);
    else
      whiterampup = whiteramptime;
  int whiterampdown;
    if (((ontime * 60) + photoperiod + blueramptime + whiteramptime) <= daybyminute)
      whiterampdown = (((ontime*60) + photoperiod + blueramptime + 2*whiteramptime) - daybyminute);
    else
      whiterampdown = whiteramptime;
  int bluerampdown;
    if (((ontime * 60) + photoperiod + blueramptime + 2*whiteramptime) <= daybyminute)
      bluerampdown = (((ontime*60) + photoperiod + 2*blueramptime + 2*whiteramptime) - daybyminute);
    else
      bluerampdown = blueramptime;
  /*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  L O O P - F A D E  I N |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
    if (daybyminute <= ((ontime*60) + blueramptime + (whiteramptime/10*9))) //if time is in range of fade in, start fading in + (whiteramptime/10*9)
      // fade blue LEDs in from min to max.
      for (int i = 1; i <= 10; i++) // setting ib value for 10% increment. Start with 0%
        analogWrite(blue, bluepercent[i]);
        lcd.setCursor(5, 1);
        lcd.print(i);
        lcd.print(" ");
        int countdown = ((bluerampup*60)/10); // calculates seconds to next step
        while (countdown>0)
          onesecond(); // updates clock once per second
          countdown--;
          relay2();
          relay1();
      // fade white LEDs in from min to max.
      for (int i = 1; i <= 10; i++) // setting i value for 10% increment. Start with 0%
        analogWrite(white, whitepercent[i]);
        lcd.setCursor(14, 1);
        lcd.print(i);
        lcd.print(" ");
        int countdown = ((whiterampup*60)/10); // calculates seconds to next step
        while (countdown>0)
          countdown--;
          relay2();
          relay1();
  /*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  L O O P - M A X  V A L U E |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
if (daybyminute >= ((ontime * 60) + blueramptime + whiteramptime))
    if ( daybyminute < ((ontime * 60) + blueramptime + whiteramptime + photoperiod)) // if time is in range of photoperiod, turn lights on to maximum fade value
      analogWrite(blue, 255);
        lcd.print(10);
        lcd.print(" ");
      analogWrite(white, 255);
        lcd.print(10);
        lcd.print(" ");
  /*|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||  L O O P - F A D E  O U T |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||*/
    if (((ontime * 60) + photoperiod + whiteramptime + 2*blueramptime + (blueramptime/10*9)) >= daybyminute)
      // fade white LEDs out from max to min in increments of 1 point:
      for (int i = 10; i >= 0; i--) // setting i value for 10% increment. Start with 10%
        lcd.print(10);
        lcd.print(" ");
        lcd.print(i);
        lcd.print(" ");
        int countdown = ((whiterampdown*60)/10); // calculates seconds to next step
        while (countdown>0)
          countdown--;
          relay2();
          relay1();
      // fade blue LEDs out from max to min in increments of 1 point:
        lcd.print(i);
        lcd.print(" ");
        int countdown = ((bluerampdown*60)/10); // calculates seconds to next step
        while (countdown>0)
          countdown--;
          relay2();
          relay1();
}  // END LOOP
By Hector
#6647
The RTC module is not modular, it does not insert. You need to make the wiring. The LCD uses Digital pins 4,5,6,7,8,9. You can use all the other pins, you might need to use different kinds of wire or solder some wire to the LCD shield to achieve the proper connection.
Just create the same wiring as the wiring diagram, but instead of directly on the Arduino, do it on the LCD Shield.
