Connect BLUNO to android app?
Unread postPosted:Fri Aug 02, 2019 2:44 pm
by joshgang
Im doing a school project and I want the bluno beetle to send data to an android app on my phone that i created. I created the app using MIT app inventor software. I am able to connect my phone to the bluno but when i go in the app and try to connect the app to the bluno it says "check device settings, make sure the device is turned on". Now this could be a problem with my app but I want to troubleshoot the bluno first, is there a way i can edit bluno settings to make it recognizable? How can i connect the bluno to an app that isnt the bluno app you download. Every video ive found is people connecting the bluno to the bluno app but if thats all it can do thats really pointless. Also what is the difference between link and pair. When I connect the bluno to my devices the LED for the link goes off but ive never seen the pair.n
Re: Connect BLUNO to android app?
Unread postPosted:Mon Aug 05, 2019 6:37 am
by nana.wang
Hi thanks for your support.
Yes, it can pair APP designed by users, please try checking the source code for reference.
It contains the way to pair.
Unread postPosted:Mon Aug 05, 2019 10:51 pm
by joshgang
Why does it pair to my phone but when i try and connect it through the app it says device not found?
Unread postPosted:Tue Aug 06, 2019 6:55 am
by nana.wang
It is the App problem.
Unread postPosted:Tue Feb 18, 2020 10:23 am
by reginaldsautter6
DFRobot does provide example iOS and Android projects. However, as I was making my app with the Unity game engine. I could not use that directly krogerfeedback
Unread postPosted:Tue Nov 24, 2020 11:28 am
by lafnian1990
It seems to me that this program requires permission from root or other technical protocols. Android often uses this simple technology to check for suspicious programs. I recently tried to download a book on two media at the same time and my phone gave an error. The main nuance is the use of a static address for two devices.
Unread postPosted:Tue Mar 09, 2021 10:23 am
by finistratbob
It seems to me that the problem may be in the content formatting. I recently downloaded the book "The Cask of Amontillado" and this resource https://freebooksummary.com/category/th ... ado-themes allowed me to choose the format of the review. It seems to me that good resources give me the right to choose and the ability to quickly navigate. This is a cool book for fans of historical and adventure novels.
