[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 580: sizeof(): Parameter must be an array or an object that implements Countable
[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 636: sizeof(): Parameter must be an array or an object that implements Countable
Need a help - Arduino Robot IOT Community Forum - DFRobot
By ruspelirzi
#30391
Hi!
I followed the Wiki on how to use this motor driver. Double checked on oscilloscope on the servo pulse timing.
Here is the symptom:
1) Individual controlling CH1 and CH2 no issue - works as specs
Kindly advise whether is the firmware of the board need to be updated?
Thanks.
By nana.wang
#30408
Hi thanks for your support.
Could you please offer the SKU no. for our reference? Or you mean CH1 and CH2 in Vortex?
