- Thu Jun 18, 2020 1:58 pm
#42385
The xbee radios i'm using i test them with a different arduinos (uploading code) the work good like i said same baudrate,and on the xboard i can't get to blink an led thru xbee.
The sketch you have for the tutorial it freezes, is there any other example code you may have? to see if the x board works or is it faulty?
By the way, i've check for continuty with my multimeter and on the xboard where the xbee sits there's no continuty between the "tx and the tx (on the programing port)" "rx to rx" there's continuty.
thank you there
automobile
thank you there
automobile
