How to Make a DIY Music Player?
Unread postPosted:Fri Jul 14, 2017 7:06 am
by naddour
I always want to make a DIY music player, but I don’t know why I failed every time. So I searched information on line and I finally found a guide at other forum.
Components:
DFRduino UNO R3 (same as Arduino UNO Rev3)*1
IR Kit for Arduino*1
DFPlayer - A Mini MP3 Player For Arduino *1
Jumper Wires
Resistors
Official statement:
Arduino can be directly used to supply power for this module, which will not cause any impact on Arduino.
If you use Arduino to supply power, be sure to add two 1K resistors on the serial-port communication port to eliminate the noise!
The circuit below has been constructed:
Step 1: Code
Code: Select all
*  name:     DFPlayer_Mini_Mp3
*  version:  1.0
*  Author:   Apple tec.<[email][email protected][/email]>
*  Date:     2015-07-16
*  Description:
*  note: mp3 file must put into mp3 folder in your tf card
#include
#include
#include
//定义对应16进制数值的常量名
#define POWER   0xFD00FF
#define VOLUP   0xFD807F       //VOL+
#define STOP    0xFD40BF       //FUNC/STOP
#define PREV    0xFD20DF
#define PAUSE   0xFDA05F
#define NEXT    0xFD609F
#define DOWN    0xFD10EF
#define VOLDOWN 0xFD906F       //VOL-
#define UP      0xFD50AF
#define ZERO    0xFD30CF       //0
#define EQ      0xFDB04F       //EQ
#define REPT    0xFD708F       //ST/REPT
#define ONE     0xFD08F7       //1
#define TWO     0xFD8877       //2
#define THREE   0xFD48B7       //3
#define FOUR    0xFD28D7       //4
#define FIVE    0xFDA857       //5
#define SIX     0xFD6897       //6
#define SEVEN   0xFD18E7       //7
#define EIGHT   0xFD9867       //8
#define NINE    0xFD58A7       //9
int recvPin = 2;
boolean a = true;
int i = 20;
int z = 0;
IRrecv recv(recvPin);
decode_results res;
void setup() {
  Serial.begin(9600);
  recv.enableIRIn();
  mp3_set_serial (Serial);
  mp3_set_volume (i);
  mp3_set_EQ (z);
void loop() {
  if(recv.decode(&res)) {
    switch(res.value) {
      case POWER:
      if (a == false) {
        a = !a;
        mp3_stop ();
      break;
      case PREV:
      if (a == true) {
        a = !a;
      mp3_prev ();
      break;
      case NEXT:
      if (a == true) {
        a = !a;
      mp3_next ();
      break;
      case PAUSE:
      if (a == true) {
        a = !a;
        mp3_play ();
      else {
        a = !a;
        mp3_pause ();
      break;
      case VOLUP:
      if (i < 30) {
        i = i+1;
        mp3_set_volume (i);
      break;
      case VOLDOWN:
      if (i > 0) {
        i = i-1;
        mp3_set_volume (i);
      break;
      case EQ:
      if (z < 5) {
        z = z+1;
      else {
        z = 0;
      mp3_set_EQ (z);
      break;
      case REPT :
      if (a == true) {
        a = !a;
      mp3_random_play ();
      break;
      case ONE:
      if (a == true) {
        a = !a;
      mp3_play (1);
      break;
      case TWO:
      if (a == true) {
        a = !a;
      mp3_play (2);
      break;
      case THREE:
      if (a == true) {
        a = !a;
      mp3_play (3);
      break;
      case FOUR:
      if (a == true) {
        a = !a;
      mp3_play (4);
      break;
      case FIVE:
      if (a == true) {
        a = !a;
      mp3_play (5);
      break;
      case SIX:
      if (a == true) {
        a = !a;
      mp3_play (6);
      break;
      case SEVEN:
      if (a == true) {
        a = !a;
      mp3_play (7);
      break;
      case EIGHT:
      if (a == true) {
        a = !a;
      mp3_play (8);
      break;
      case NINE:
      if (a == true) {
        a = !a;
      mp3_play (9);
      break;
      default:
      recv.resume();
Step 2: IR Remote Control Music Player
If everything goes well, you will get a music player controlled by IR remote control unit.
* Please carefully read the notes on use of DFPlayer Mini Module below!
* DFPlayer Mini can read files in MP3 & WAV format (the actual test indicates 320K super high quality music can be decoded), but audios with duration less than 1 second cannot be played.
* Be sure to place all music files in MP3 folder, and MP3 files shall be named with four digits, e.g., "0001.mp3", and then placed in MP3 folder. If Chinese or English name is required, English words shall be added at the rear of digits, e.g., "0001hello.mp3" or "0001后来.mp3". See the data manual for the details.
DFPlayer mini library files used in the code have been modified, and “all cycle” function is added.
Re: How to Make a DIY Music Player?
Unread postPosted:Sat Oct 20, 2018 8:37 am
by sonidosgratis102
Thank for your writting.
Unread postPosted:Tue Dec 29, 2020 7:56 am
by jerremyhamston
Have you finished your music player product yet? I really want to experience it
shzz
Unread postPosted:Wed Jan 06, 2021 2:26 pm
by vojowew649
mnay thanks
Unread postPosted:Mon Feb 08, 2021 9:24 am
by jacquelynpatte1.9
A debt of gratitude is in order for Sharing data.
Unread postPosted:Sun Feb 14, 2021 12:40 pm
by raresky1
Solder the header pins with a soldering iron. Be careful while soldering!
Take the FM-16p speaker and solder the two input terminals of the speaker to the mini-player.
Put the FM speaker in the plastic box for audio amplification.
Connect the momentary push button to the plastic box for changing the output. The push-button is used to change the output by triggering the input from the external source. The audio amplification of the circuit is done by connecting the speaker directly to the power source.
Connect the LED light to the circuit for getting the signal about its present condition. If the LED light flashes, it indicates the ON condition and vice versa for the MP3 circuit.
Connect the power supply to the circuit. After a moment, the LED should start flashing, representing that it is working.
Cover the plastic box carefully without breaking any connecting wires
