FORUM RULES - PLEASE READ It!
Unread postPosted:Wed Jan 27, 2016 3:34 am
by Maht
The DFRobot Maker Community is in place to help users with DFRobot product issues, help with project implementation and general engineering-related queries. It is also a place where you can showcase your work and share ideas with other makers.
RULES:
  • This is a friendly forum - rude or offensive posts will not be tolerated.
    This is a community for makers and not an advertising space - links to commercial concerns will be considered spam and deleted. Repeat offenders will be banned.
In order to help each other as quickly and efficiently as possible, we suggest following these guidelines:
GUIDE FOR ASKING TECHNICAL QUESTIONS:
First, if you haven’t already, check the product wiki for information:
http://www.dfrobot.com/wiki/index.php?title=Main_Page
You can search for the product you are having problems with by entering the SKU in the search bar (e.g. ROBxxxx, KITxxxx, SENxxxx, etc.) You can also use the product name to search.
If you have checked the product wiki and haven’t found what you need, please do post questions on our forum!
In your post please include the following information if you can:
• The SKU of the product you are having issues with (e.g. ROBxxxx, KITxxxx, SENxxxx, etc.)
• What IDE are you using? (e.g. Arduino IDE v 1.7.9)
• What is the intended function of your project?
• Are you using any libraries? Links to the source are helpful!
• Provide a sample of the code you are using between code tags so we can easily check it for any errors, e.g.:
Code: Select all
void setup() {
  // put your setup code here, to run once:
void loop() {
  // put your main code here, to run repeatedly:
Feel free to provide any other details that you think might help - the more detail, the better.
When you have posted, one of our moderators will get back to you as soon as we can!
(Of course, you don't have to follow these guidelines, but it might take us longer to help you if we don't have enough information!)
Do you see any mistakes on our wiki? Spelling, grammar, technical errors? Please do let us know on the forum so we can make it better.
Re: FORUM RULES - PLEASE READ!
Unread postPosted:Thu Jan 25, 2018 3:04 am
by microsoftcustomersupoffpage
I got it.Thanks for accept my account.
Re: FORUM RULES - PLEASE READ It!
Unread postPosted:Wed Mar 31, 2021 12:13 pm
by 1sashkagonchar1
nice thank you for the info
Unread postPosted:Fri Apr 23, 2021 7:09 am
by tatealex001
It is important for beginners to know the basics before they start working with the programming language and writing assignments on it. This article is all about the basic concepts of java that are beneficial to beginners. https://www.allassignmentservices.com/e ... ment-help/
Unread postPosted:Fri Apr 23, 2021 8:33 am
by carolynnursela
this is really good, thank you for sharing with us vidmate app mobdro apk
Unread postPosted:Tue Apr 27, 2021 2:47 pm
by selenaemani315
thanks for sharing with us
Unread postPosted:Fri Jun 11, 2021 6:26 am
by willisvalenzuela548365
Thanks for sharing! It's really helpful to me.
taming io
