HuskyLens With Raspberry
Unread postPosted:Fri Dec 18, 2020 10:00 am
Hi everyone,
I'm having some problems configuring HuskyLens with Raspbery Pi.
I have connected Huskylens to I2C and set up I2C in the chamber.
When I run the example script from the library however it generates an error, where am I going wrong?
this is my code:
This is the error:
First request a knock: Knock Recieved
Traceback (most recent call last):
File "/home/pi/huskycam/test/huskylib.py", line 179, in processReturnData
commandSplit[4][2:4]+commandSplit[4][0:2], 16)
TypeError: int() can't convert non-string with explicit base
During handling of the above exception, another exception occurred:
File "prova.py", line 6, in <module>
camera.algorthim("ALGORITHM_FACE_RECOGNITION")
File "/home/pi/huskycam/test/huskylib.py", line 387, in algorthim
return self.processReturnData()
File "/home/pi/huskycam/test/huskylib.py", line 217, in processReturnData
self.huskylensSer.timeout=5
AttributeError: 'SMBus' object has no attribute 'timeout'
[email protected]:~/huskycam/test $ python3 prova.py
thanks for support
Luca
this is my code:
Code: Select all
from huskylib import HuskyLensLibrary
camera = HuskyLensLibrary("I2C","",address=0x32)
print("First request a knock: {}".format(camera.knock()))
while(true):
data=camera.blocks()
x=0
for i in data:
x=x+1
print("Face {} data: {}".format(x,i))
This is the error:
thanks for support
Luca
