Husky lens serial protocol issues
Unread postPosted:Thu Apr 15, 2021 7:21 pm
by aidandecastro22
My husky lens was working fine with my Arduino after I changed the rate to 9600 baud. Not today I cannot get the Arduino to recognize the board. its working fine and its on the right baud rate but nothing.
Re: Husky lens serial protocol issues
Unread postPosted:Fri Apr 16, 2021 8:18 am
by nana.wang
You need to check whether the Arduino serial port is occupied. If they use the same hard serial port, the communication will fail.
Unread postPosted:Fri May 14, 2021 9:57 am
by jennyreed1995
In Ubuntu 18.04.4, the USB serial port of HuskyLens can be directly identified when We recommend to use the auto detection protocol, which is simple and convenient. Incompatibility problems may exist between SD cards of small brands.
