#7574
There are two methods to use the board to drive the AX/CDS55XX series servo:
:arrow: Pc software(Windows) Download
:arrow: Code on Arduino or other MCU
1 Pc Software
Wiring:
Operation
1 check usb-serial port
2 open the serial port in the software, and then serch the servo ID, if not found , please reverse your tx/rx sequence.
3 torque on and control your servo, if no reaction, please see if there was any warning from the servo( repower ), or useless power supply.
Then you will see if your AX12 CDS55xx Driver Board was broken. ;)
More about the software.
2 Code on Arduino or other MCU
:arrow: Download the library first:
(3.44 KiB) Downloaded 326 times
(3.29 KiB) Downloaded 339 times
Wiring:
I missed to add the external power adapter in the picture which are same as above.
Operation
Install the library, then upload the sample sketch without any change to the code. It will rotate endless 0-300-0-300....
(536.3 KiB) Downloaded 3355 times
3 Command Control through Serial Port
This sketch is tested on Leonardo( Serial/usb port to input command, Serial1 to control AX/CDS55xx )
(3.34 KiB) Downloaded 320 times
Wiring:
Operation
Upload the sketch and send command through the serial port. The command could be found in the sketch.
Code: Select all
switch (command) {
  case 'p':      //move to value (0~300) "p x x"
    cds55_pos (id, value);
    break;
  case 'r':      //reset servo "r x"
    cds55_reset (id);
    break;
  case 'l':      //open or close led by 1 or 0 "l x x"
    cds55_led (id, value);
    break;
  case 't':      //enable or disable torque by 1 or 0 "t x x"
    cds55_torque (id, value);
    break;
  case 'i':      //change id to newid by value "i x x"
    cds55_setID (id, value);
    break;
  case 'v':      //change move velocity "v x x"
    cds55_velocity (id, value);
    break;
  default:
    Serial.println ("error! no this command!");
(561.81 KiB) Downloaded 3348 times
