MIND+ 1.56 Release micro:bit problem
Unread postPosted:Fri Jul 12, 2019 8:01 am
by tguneysu
All of a sudden the micro:bit button press HAT blocks are not working in the last release (v1.56)
In the ONLINE mode, the individual detection block (is button A pressed?) will work, but the HAT block does not detect the press and execute code under it.
Same code loaded in the OFFLINE mode will work OK.
micro:bit is connected, driver loaded, and other functions are working.
I reloaded version 1.53, and all the blocks are working perfectly!
Re: MIND+ 1.56 Release micro:bit problem
Unread postPosted:Thu Jul 25, 2019 7:07 am
by tguneysu
two weeks and no reply at all !!!!!
