By madlan
#44865
I would like to use the SHT30 sensor in high humidity conditions for continuous reading.
https://wiki.dfrobot.com/SHT30%20Digita ... %20SEN0330
Does anyone have an example of how to manage the heater? Should it be switched on permanently white in the high humidity environment or should it only be switched on for a short period before taking a reading?
Is there an algorithm to compensate for the increased temperature and lower humidity reading while the heater is on?
