Very frustrated with Gesture Recognition Touch Sensor
Unread postPosted:Fri Nov 13, 2020 8:09 pm
A buddy and I share this hobby together and we were excited to play with this gesture sensor on an Arduino Uno. But all we get is (-1) DF_ERR.
We have used this Arduino Uno board for other dev projects and we use the power supplied by USB cable from computer. We wired it up. Double checked each other's work. Checked the continuity of all connections with meter. Downloaded the software library and copied the sample code from GitHub. We get a clean compile. We are getting a response from the instantiated object. The only response is DF_ERR. No response to gestures. No response to touch pad.
We may have bad hardware. Are there other tests I might be able to try?
