By tguneysu
#30063
In the new version, in ONLINE mode, the event HAT blocks do not detect button presses, shakes, etc.
They all worked correctly in the v1.53.
I have reported other button press issues earlier. But I think they all originate from the same problem, that events blocks are not activated.
Very urgent, as it makes the micro:bit unusable.
thx.
By 1938391275
#30207
Hi, really sorry for the late reply.
First of all, thank you for your support about our Product. Here is the solution for your problem:
If now you are in English Interface, switch to Chinese, switch to English, close and reopen the software, then all the blocks should work fine; If you not in English Interface currently, switch to English, close and reopen Mind+.
Hope this helps! If you still have any questions, please let us know, we will try our best to make it right!
By tguneysu
#30260
OK. That has temporarily solved the problem!
However, since MIND+ is SCRATCH3 based and there is such problem in S3, you guys have injected a problem into the language switching portion of the code. Would it not be better for you to fix the problem than make the user go through language selection acrobatics to make your code initialize properly ?
By jonesann1098
#33103
tguneysu wrote:
Fri Jul 12, 2019 8:39 am
They all worked correctly in the v1.53. - it was th time when I was studying with the help of
thx.
Sure, the v1.53 was good and acceptable at that time.
#45101
We are a US-based company that provides logos for sale which are affordable and high on quality. Our custom web design services are of the highest quality and help create brand identities. We understand how important it is to have a good web design and the role it plays in helping grow a company successfully. Our clientele prefers our services due to their outstanding work and timely delivery for affordable prices. Our team of highly skilled graphic designers will always provide the most appropriate web design which combines the highest quality designs and innovative strategies for our customers. Our designers spend time getting to know your business and objectives. With our customized web design, you will be able to create an excellent impression on your viewers. Therefore, you should consult Logo Cravings in the US to begin your journey to the growth of your company.
