I don't know if you need an example of makecode or Arduino. So I give you the easiest way I know is to download Mind+ http://mindplus.cc/en.html
You can find micro:bit and MP3 in the graphical programming components above
DFR0440 can be similar to motor drive, you can still find a solution in Mind+
