By Marcox81
#5770
Hi @all.
I've got the OBD2 KIT #1; all seems ok but the OBD doesn't connect;
I plug the usb or car AC > OBD blink blue for a second then stop on red > on the OLED:
"SDHC 8GB
OBD X
dfrobot X"
The OBD adapter is the "I2C Adapter"  and I've connected it to pin 4 (+) and 6 (-) of ICSP;
yellow > TX1; white > RX0 on Arduino
The TX led on arduino blink every 2 second but OBD is still in "X"
Any help?
Many thanks
By Marcox81
#5771
Updated config and changed in nanologger.ino the line 268 to "recover();" as suggested by Stanley.
Now I've another problem, the arduino connect to my Toyota yaris, but don't connect to my Ducati wirh Marelli ECU (IAW5AM), that use the ISO9141-2 protocols
This protocol is supported from the OBD, but it doesn't.
Any help please!
By Vaso
#5772
[quote="Marcox81"]
Any help please!
[/quote]
Some Info about Ducati wirh Marelli ECU (IAW5AM):
Standard KWP2000, ISO 14230-4
Speed 38400bps
Startup sequence auto-reply to the ECU on power up a certain ISO hex code (55 B0 80 80 80 85) at a specific timing interval
Marcox81, did you solve your problem?
By fblogin2016.com
#9908
Thanks for sharing. I hope it will be helpful for too many people that are searching for this topic.
fb login
By rosymalhotra9
#9948
Impressive articel and wanna say thanks a lot for providing some info about OBD Communication. These are similar problems which can be happen any moment. thanks a lot for the perfect way to get rid from it. Thanks a lot. Meet Russian Amritsar Escorts
