By nakosmeister - Fri May 24, 2019 7:14 am
#29563
I Installed Windows 10 Professional and downloaded the drivers from here
https://github.com/LattePandaTeam/Latte ... 0-Software
Unfortunately I can install the drivers running the setup file.
This is the log output
09:47:20:246: >>> Log start
09:47:20:251: Core version: 2.0.5
09:47:20:255: Setup version: 2.0.0.11
09:47:20:259: Command line: "C:\LattePanda-Win10-Software-master\LattePanda-Win10-Software-master\Drivers\2G32GB_Drivers\All-in-one Pack\CHT T3 MRD PR2 Driver WW51.2\Installer\PlatformInstaller\Setup.exe"
09:47:20:266: OS data: 6-2-1-0 64-bit
09:47:20:270: System up time: 3814 sec
09:47:20:274: Current UI language: 0409
09:47:20:280: Language folder: C:\Users\nakosi\AppData\Local\Temp\IIF336A.tmp
09:47:20:381: Found C:\Users\nakosi\AppData\Local\Temp\IIF336A.tmp\en-US\IntelCommon.dll. Lang 0409. Rank 3
09:47:20:411: Relaunching setup as elevated
09:47:24:153: Dumping MSI properties (0 total)
09:47:24:158: Exit code: 0
09:47:24:163: >>> Log End
09:47:24:348: >>> Log start
09:47:24:356: Core version: 2.0.5
09:47:24:361: Setup version: 2.0.0.11
09:47:24:366: Command line: "C:\LattePanda-Win10-Software-master\LattePanda-Win10-Software-master\Drivers\2G32GB_Drivers\All-in-one Pack\CHT T3 MRD PR2 Driver WW51.2\Installer\PlatformInstaller\Setup.exe"
09:47:24:370: OS data: 6-2-1-0 64-bit
09:47:24:374: System up time: 3818 sec
09:47:24:378: Current UI language: 0409
09:47:24:385: Language folder: C:\Users\nakosi\AppData\Local\Temp\IIF4367.tmp
09:47:24:479: Found C:\Users\nakosi\AppData\Local\Temp\IIF4367.tmp\en-US\IntelCommon.dll. Lang 0409. Rank 3
09:47:24:510: Package version: 1.1.1.1
09:47:24:514: Installed version: <Not installed>
09:47:24:522: This is a clean install
09:47:24:526: Setup mode: Installation
09:47:24:531: Looking for OS: 6.0
09:47:24:536: OS check passed
09:47:24:540: .NET not required, skipping requirement check
09:47:24:544: Driver source is C:\LattePanda-Win10-Software-master\LattePanda-Win10-Software-master\Drivers\2G32GB_Drivers\All-in-one Pack\CHT T3 MRD PR2 Driver WW51.2\Installer\PlatformInstaller\Drivers
09:47:24:548: Using folder 'C:\LattePanda-Win10-Software-master\LattePanda-Win10-Software-master\Drivers\2G32GB_Drivers\All-in-one Pack\CHT T3 MRD PR2 Driver WW51.2\Installer\PlatformInstaller\Drivers' as the driver source
09:47:24:552: Scanning all active devices
09:47:24:638: Scanning Audio\AudioRealtek\isstrtc\isstrtc.inf (Name: Audio\AudioRealtek\isstrtc\isstrtc.inf, Version: 604.10135.2747.5232)
09:47:24:643: Section with the best match: IntelSST.NTamd64
09:47:24:647: Device: ACPI\80860F28 (Intel SST Audio Device (WDM))
09:47:24:652: Device: ACPI\808622A8 (Intel SST Audio Device (WDM))
09:47:24:697: Matched with: ACPI\808622A8
09:47:24:702: No pre-existing driver found
09:47:24:707: MUP OS bits: 0x3FFFF
09:47:24:712: Adding Audio\AudioRealtek\isstrtc\isstrtc.inf to the map...
09:47:24:728: Scanning Audio\AudioRealtek\rtii2sac\rtii2sac.inf (Name: Audio\AudioRealtek\rtii2sac\rtii2sac.inf, Version: 6.4.10147.4315)
09:47:24:736: Section with the best match: Realtek.NTamd64
09:47:24:741: Device: ACPI\INTCCFFD (Realtek I2S Audio Codec)
09:47:24:745: Device: ACPI\10EC5640 (Realtek I2S Audio Codec)
09:47:24:748: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_221C17AA (Realtek I2S Audio Codec)
09:47:24:753: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_221B17AA (Realtek I2S Audio Codec)
09:47:24:757: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_398517AA (Realtek I2S Audio Codec)
09:47:24:762: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_17AA3985 (Realtek I2S Audio Codec)
09:47:24:766: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_103C2177 (Realtek I2S Audio Codec)
09:47:24:770: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_103C8011 (Realtek I2S Audio Codec)
09:47:24:774: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_103C8021 (Realtek I2S Audio Codec)
09:47:24:779: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_103C8031 (Realtek I2S Audio Codec)
09:47:24:783: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_103C8032 (Realtek I2S Audio Codec)
09:47:24:787: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_103C8048 (Realtek I2S Audio Codec)
09:47:24:791: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_103C8049 (Realtek I2S Audio Codec)
09:47:24:795: Device: ACPI\VEN_10EC&DEV_5642&SUBSYS_103C815D (Realtek I2S Audio Codec)
09:47:24:799: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_103C815D (Realtek I2S Audio Codec)
09:47:24:804: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_MSHW2446 (Realtek I2S Audio Codec)
09:47:24:808: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_F9800030 (Realtek I2S Audio Codec)
09:47:24:813: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_1179F982 (Realtek I2S Audio Codec)
09:47:24:817: Device: ACPI\VEN_10EC&DEV_5642&SUBSYS_1043143D (Realtek I2S Audio Codec)
09:47:24:826: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_104314ED (Realtek I2S Audio Codec)
09:47:24:830: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_104316BD (Realtek I2S Audio Codec)
09:47:24:835: Device: ACPI\VEN_10EC&DEV_5642&SUBSYS_1043159D (Realtek I2S Audio Codec)
09:47:24:839: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_1043173D (Realtek I2S Audio Codec)
09:47:24:843: Device: ACPI\VEN_10EC&DEV_5642&SUBSYS_1043175D (Realtek I2S Audio Codec)
09:47:24:848: Device: ACPI\VEN_10EC&DEV_5642&SUBSYS_104317CD (Realtek I2S Audio Codec)
09:47:24:852: Device: ACPI\VEN_10EC&DEV_5642&SUBSYS_1043182D (Realtek I2S Audio Codec)
09:47:24:856: Device: ACPI\VEN_10EC&DEV_5648&SUBSYS_104318BD (Realtek I2S Audio Codec)
09:47:24:860: Device: ACPI\VEN_10EC&DEV_5648&SUBSYS_104318CD (Realtek I2S Audio Codec)
09:47:24:864: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_1043190D (Realtek I2S Audio Codec)
09:47:24:869: Device: ACPI\VEN_10EC&DEV_5642&SUBSYS_1043198D (Realtek I2S Audio Codec)
09:47:24:873: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_10431A0D (Realtek I2S Audio Codec)
09:47:24:877: Device: ACPI\VEN_10EC&DEV_5642&SUBSYS_104313AF (Realtek I2S Audio Codec)
09:47:24:881: Device: ACPI\VEN_10EC&DEV_5648&SUBSYS_10431BDD (Realtek I2S Audio Codec)
09:47:24:885: Device: ACPI\VEN_10EC&DEV_3270&SUBSYS_104314FF (Realtek I2S Audio Codec)
09:47:24:890: Device: ACPI\VEN_10EC&DEV_5672&SUBSYS_102806E7 (Realtek I2S Audio Codec)
09:47:24:895: Device: ACPI\VEN_10EC&DEV_5672&SUBSYS_102806EA (Realtek I2S Audio Codec)
09:47:24:899: Device: ACPI\VEN_10EC&DEV_5672&SUBSYS_102806EB (Realtek I2S Audio Codec)
09:47:24:903: Device: ACPI\VEN_10EC&DEV_5645&SUBSYS_1179F860 (Realtek I2S Audio Codec)
09:47:24:908: Device: ACPI\VEN_10EC&DEV_5645&SUBSYS_1179F861 (Realtek I2S Audio Codec)
09:47:24:913: Device: ACPI\VEN_10EC&DEV_5672&SUBSYS_1179F862 (Realtek I2S Audio Codec)
09:47:24:917: Device: ACPI\VEN_10EC&DEV_5672&SUBSYS_1179F863 (Realtek I2S Audio Codec)
09:47:24:921: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_103C22B8 (Realtek I2S Audio Codec)
09:47:24:925: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_103C22B9 (Realtek I2S Audio Codec)
09:47:24:930: Device: ACPI\VEN_10EC&DEV_5672&SUBSYS_117906BC (Realtek I2S Audio Codec)
09:47:24:935: Device: ACPI\VEN_10EC&DEV_5672&SUBSYS_103C8160 (Realtek I2S Audio Codec)
09:47:24:940: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_1019980B (Realtek I2S Audio Codec)
09:47:24:945: Device: ACPI\VEN_10EC&DEV_5645&SUBSYS_20150601 (Realtek I2S Audio Codec)
09:47:24:950: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_8046103C (Realtek I2S Audio Codec)
09:47:24:959: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_103C8177 (Realtek I2S Audio Codec)
09:47:24:963: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_103C8178 (Realtek I2S Audio Codec)
09:47:24:967: Device: ACPI\VEN_10EC&DEV_5672&SUBSYS_10251021 (Realtek I2S Audio Codec)
09:47:24:973: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_1179F850 (Realtek I2S Audio Codec)
09:47:24:977: Device: ACPI\VEN_10EC&DEV_5640&SUBSYS_1179F851 (Realtek I2S Audio Codec)
09:47:24:983: Device: ACPI\221C17AA (Realtek I2S Audio Codec)
09:47:24:987: Device: ACPI\10EC5642 (Realtek I2S Audio Codec)
09:47:24:992: Device: ACPI\10EC5645 (Realtek I2S Audio Codec)
09:47:25:019: Matched with: ACPI\10EC5645
09:47:25:024: No pre-existing driver found
09:47:25:029: MUP OS bits: 0x3FFFF
09:47:25:034: Adding Audio\AudioRealtek\rtii2sac\rtii2sac.inf to the map...
09:47:25:042: Scanning BM\IntelBatteryManagement.inf (Name: BM\IntelBatteryManagement.inf, Version: 604.10146.2444.9650)
09:47:25:048: Section with the best match: Standard.NTamd64
09:47:25:053: Device: ACPI\INT33FE (Intel(R) Battery Management Device)
09:47:25:058: MUP OS bits: 0x3FFFF
09:47:25:065: Adding BM\IntelBatteryManagement.inf to the map...
09:47:25:081: Scanning Camera\iacamera32\iacamera32.inf (Name: Camera\iacamera32\iacamera32.inf, Version: 21.10154.6023.441)
09:47:25:085: No section match
09:47:25:090: MUP OS bits: 0x92AB
09:47:25:094: Adding Camera\iacamera32\iacamera32.inf to the map...
09:47:25:102: Scanning Camera\iaisp32\iaisp32.inf (Name: Camera\iaisp32\iaisp32.inf, Version: 21.10154.6023.441)
09:47:25:107: No section match
09:47:25:111: MUP OS bits: 0x92AB
09:47:25:117: Adding Camera\iaisp32\iaisp32.inf to the map...
09:47:25:126: Scanning Camera\ov2680\ov2680.inf (Name: Camera\ov2680\ov2680.inf, Version: 604.10146.2443.6099)
09:47:25:131: No section match
09:47:25:135: MUP OS bits: 0x92AB
09:47:25:140: Adding Camera\ov2680\ov2680.inf to the map...
09:47:25:146: Scanning Camera\ov8858\ov8858.inf (Name: Camera\ov8858\ov8858.inf, Version: 21.10154.6023.441)
09:47:25:151: No section match
09:47:25:155: MUP OS bits: 0x92AB
09:47:25:160: Adding Camera\ov8858\ov8858.inf to the map...
09:47:25:167: Scanning CWS\BT\Realtek\rtkuart.inf (Name: CWS\BT\Realtek\rtkuart.inf, Version: 1.0.183.2)
09:47:25:172: No section match
09:47:25:176: MUP OS bits: 0x0
09:47:25:180: Adding CWS\BT\Realtek\rtkuart.inf to the map...
09:47:25:190: Scanning CWS\NFC\Intel\x86\Intelnfc.inf (Name: CWS\NFC\Intel\x86\Intelnfc.inf, Version: 3.0.0.32)
09:47:25:194: Section with the best match: Standard.NTAMD64
09:47:25:198: Device: ACPI\INT339A (Intel(R) Near Field Communication Device)
09:47:25:203: MUP OS bits: 0x3FFFF
09:47:25:207: Adding CWS\NFC\Intel\x86\Intelnfc.inf to the map...
09:47:25:223: Scanning CWS\WIFI\Realtek\netrtwlans.inf (Name: CWS\WIFI\Realtek\netrtwlans.inf, Version: 3008.15.0715.2015)
09:47:25:227: No section match
09:47:25:230: MUP OS bits: 0x0
09:47:25:234: Adding CWS\WIFI\Realtek\netrtwlans.inf to the map...
09:47:25:242: Scanning DPTF\dptf_acpi.inf (Name: DPTF\dptf_acpi.inf, Version: 8.1.10900.175)
09:47:25:246: No section match
09:47:25:250: MUP OS bits: 0x92AB
09:47:25:254: Adding DPTF\dptf_acpi.inf to the map...
09:47:25:261: Scanning DPTF\dptf_cpu.inf (Name: DPTF\dptf_cpu.inf, Version: 8.1.10900.175)
09:47:25:264: No section match
09:47:25:268: MUP OS bits: 0x92AB
09:47:25:272: Adding DPTF\dptf_cpu.inf to the map...
09:47:25:278: Scanning DPTF\dptf_pch.inf (Name: DPTF\dptf_pch.inf, Version: 8.1.10900.175)
09:47:25:282: No section match
09:47:25:285: MUP OS bits: 0x92AB
09:47:25:289: Adding DPTF\dptf_pch.inf to the map...
09:47:25:299: Scanning DPTF\esif_manager.inf (Name: DPTF\esif_manager.inf, Version: 8.1.10900.175)
09:47:25:303: No section match
09:47:25:307: MUP OS bits: 0x9200
09:47:25:310: Adding DPTF\esif_manager.inf to the map...
09:47:25:320: Scanning GNSS\gnssDriver.inf (Name: GNSS\gnssDriver.inf, Version: 32.2.0.18)
09:47:25:324: No section match
09:47:25:327: MUP OS bits: 0x92AB
09:47:25:331: Adding GNSS\gnssDriver.inf to the map...
09:47:25:339: Scanning GPIO\iagpioe.inf (Name: GPIO\iagpioe.inf, Version: 604.10146.2652.3930)
09:47:25:344: No section match
09:47:25:349: MUP OS bits: 0x92AB
09:47:25:354: Adding GPIO\iagpioe.inf to the map...
09:47:25:416: Scanning Graphics\igdlh.inf (Name: Graphics\igdlh.inf, Version: 20.19.15.4331)
09:47:25:421: No section match
09:47:25:425: MUP OS bits: 0x9200
09:47:25:430: Adding Graphics\igdlh.inf to the map...
09:47:25:456: Scanning I2C\iai2ce.inf (Name: I2C\iai2ce.inf, Version: 604.10146.2654.7394)
09:47:25:460: No section match
09:47:25:464: MUP OS bits: 0x92AB
09:47:25:467: Adding I2C\iai2ce.inf to the map...
09:47:25:475: Scanning ISH\AdvSensorHIDClassDriver\AdvSensorClassDriver.inf (Name: ISH\AdvSensorHIDClassDriver\AdvSensorClassDriver.inf, Version: 2.0.20.3155)
09:47:25:479: No section match
09:47:25:483: MUP OS bits: 0x9200
09:47:25:487: Adding ISH\AdvSensorHIDClassDriver\AdvSensorClassDriver.inf to the map...
09:47:25:494: Scanning ISH\AdvSensorHIDClassDriverV2\AdvSensorHIDClassDriverV2.inf (Name: ISH\AdvSensorHIDClassDriverV2\AdvSensorHIDClassDriverV2.inf, Version: 2.0.20.3157)
09:47:25:498: No section match
09:47:25:502: MUP OS bits: 0x92AB
09:47:25:506: Adding ISH\AdvSensorHIDClassDriverV2\AdvSensorHIDClassDriverV2.inf to the map...
09:47:25:512: Scanning ISH\Bus\ISH_BusDriver.inf (Name: ISH\Bus\ISH_BusDriver.inf, Version: 2.0.20.3159)
09:47:25:516: No section match
09:47:25:519: MUP OS bits: 0x9200
09:47:25:523: Adding ISH\Bus\ISH_BusDriver.inf to the map...
09:47:25:531: Scanning ISH\HECI_ISH\ISH.inf (Name: ISH\HECI_ISH\ISH.inf, Version: 2.0.20.3157)
09:47:25:541: No section match
09:47:25:545: MUP OS bits: 0x9200
09:47:25:550: Adding ISH\HECI_ISH\ISH.inf to the map...
09:47:25:556: Scanning ISH\HidEventFilter\HIDEventFilter.inf (Name: ISH\HidEventFilter\HIDEventFilter.inf, Version: 604.10146.2708.64268)
09:47:25:560: Section with the best match: Vendor.NTamd64
09:47:25:564: Device: ACPI\INT33D5 (Intel(R) HID Event Filter)
09:47:25:594: Matched with: ACPI\INT33D5
09:47:25:599: Current driver: oem2.inf
09:47:25:604: Name: , Provider: Intel(R), Version: 1.1.1.318, Section: HidEventFilter.Inst.NT
09:47:25:608: MUP OS bits: 0x3FFFF
09:47:25:612: Adding ISH\HidEventFilter\HIDEventFilter.inf to the map...
09:47:25:620: Scanning ISH\Miniport\HID_PCI.inf (Name: ISH\Miniport\HID_PCI.inf, Version: 2.0.20.3155)
09:47:25:625: No section match
09:47:25:630: MUP OS bits: 0x9200
09:47:25:634: Adding ISH\Miniport\HID_PCI.inf to the map...
09:47:25:641: Scanning MBI\MBI.inf (Name: MBI\MBI.inf, Version: 604.10146.2655.573)
09:47:25:645: No section match
09:47:25:649: MUP OS bits: 0x92AB
09:47:25:685: Adding MBI\MBI.inf to the map...
09:47:25:691: Scanning PMIC\pmic.inf (Name: PMIC\pmic.inf, Version: 604.10146.2656.541)
09:47:25:695: No section match
09:47:25:699: MUP OS bits: 0x92AB
09:47:25:703: Adding PMIC\pmic.inf to the map...
09:47:25:710: Scanning PSS\MonzaX.inf (Name: PSS\MonzaX.inf, Version: 1.0.11.0)
09:47:25:715: No section match
09:47:25:719: MUP OS bits: 0x92AB
09:47:25:723: Adding PSS\MonzaX.inf to the map...
09:47:25:730: Scanning SPI\iaspie.inf (Name: SPI\iaspie.inf, Version: 604.10146.2657.947)
09:47:25:735: No section match
09:47:25:739: MUP OS bits: 0x92AB
09:47:25:743: Adding SPI\iaspie.inf to the map...
09:47:25:751: Scanning Touch\package\GoodixTouchDriver.inf (Name: Touch\package\GoodixTouchDriver.inf, Version: 6.3.9600.17246)
09:47:25:756: No section match
09:47:25:762: MUP OS bits: 0x9200
09:47:25:766: Adding Touch\package\GoodixTouchDriver.inf to the map...
09:47:25:775: Scanning TXEI\TXEI.inf (Name: TXEI\TXEI.inf, Version: 2.0.0.1067)
09:47:25:779: No section match
09:47:25:783: MUP OS bits: 0x9200
09:47:25:788: Adding TXEI\TXEI.inf to the map...
09:47:25:795: Scanning UART\iauarte.inf (Name: UART\iauarte.inf, Version: 604.10146.2653.391)
09:47:25:799: No section match
09:47:25:802: MUP OS bits: 0x92AB
09:47:25:806: Adding UART\iauarte.inf to the map...
09:47:25:810: Reading config file : C:\LattePanda-Win10-Software-master\LattePanda-Win10-Software-master\Drivers\2G32GB_Drivers\All-in-one Pack\CHT T3 MRD PR2 Driver WW51.2\Installer\PlatformInstaller\Config.xml
09:47:25:816: Read SocPackageInfo Version : 0x1
09:47:25:820: Reading string value
09:47:25:824: Read XML SocPackageInfo Root : HKEY_LOCAL_MACHINE, Key : SOFTWARE\Intel\SOCPackageInfo, Value : VersionNumber, Version string name : Version, version string : 102
09:47:25:829: Registry key SOFTWARE\Intel\SOCPackageInfo does not exist or can not be read. Error : Unable to read registry value : VersionNumber - Error Code : 2. Assuming the installed version is oldest. Proceeding with installation.
09:47:25:832: Preparing UI
09:47:25:836: Reading config file : C:\LattePanda-Win10-Software-master\LattePanda-Win10-Software-master\Drivers\2G32GB_Drivers\All-in-one Pack\CHT T3 MRD PR2 Driver WW51.2\Installer\PlatformInstaller\Config.xml
09:47:25:842: Read Title Override : Intel x86 CherryTrail-T Driver Package
09:47:25:846: Reading config file : C:\LattePanda-Win10-Software-master\LattePanda-Win10-Software-master\Drivers\2G32GB_Drivers\All-in-one Pack\CHT T3 MRD PR2 Driver WW51.2\Installer\PlatformInstaller\Config.xml
09:47:25:852: Read Title Override : Intel x86 CherryTrail-T Driver Package
09:47:25:889: Showing dialog: WELCOME
09:47:27:620: Showing dialog: LICENSE
09:47:30:383: Showing dialog: CONFIRM
09:47:31:698: Started installation thread
09:47:31:706: Setup mode
09:47:31:710: Reading config file : C:\LattePanda-Win10-Software-master\LattePanda-Win10-Software-master\Drivers\2G32GB_Drivers\All-in-one Pack\CHT T3 MRD PR2 Driver WW51.2\Installer\PlatformInstaller\Config.xml
09:47:31:717: BIOS section is missing in the configuration file. Skipping the BIOS Update.
09:47:31:724: Registry checks section is missing in the configuration file. Since there is no BIOS file specified, Skipping the Registry check.
09:47:31:729: Read INF file name : MBI.inf
09:47:31:734: Read INF file name : iai2ce.inf
09:47:31:740: Read INF file name : iagpioe.inf
09:47:31:745: Read INF file name : iauarte.inf
09:47:31:750: Read INF file name : iaspie.inf
09:47:31:755: Read INF file name : pmic.inf
09:47:31:759: Read INF file name : ISH.inf
09:47:31:763: Read INF file name : ISH_BusDriver.inf
09:47:31:767: Read INF file name : HID_PCI.inf
09:47:31:772: Read INF file name : HIDEventFilter.inf
09:47:31:777: Read INF file name : AdvSensorClassDriver.inf
09:47:31:782: Read INF file name : AdvSensorHIDClassDriverV2.inf
09:47:31:786: Read INF file name : IntelBatteryManagement.inf
09:47:31:791: Read INF file name : esif_manager.inf
09:47:31:795: Read INF file name : dptf_acpi.inf
09:47:31:800: Read INF file name : dptf_cpu.inf
09:47:31:804: Read INF file name : dptf_pch.inf
09:47:31:809: Read INF file name : TXEI.inf
09:47:31:813: Read INF file name : isstrtc.inf
09:47:31:817: Read INF file name : rtii2sac.inf
09:47:31:822: Read INF file name : MonzaX.inf
09:47:31:827: Read INF file name : iacamera32.inf
09:47:31:831: Read INF file name : iaisp32.inf
09:47:31:835: Read INF file name : ov2680.inf
09:47:31:840: Read INF file name : ov8858.inf
09:47:31:844: Read INF file name : netrtwlans.inf
09:47:31:848: Read INF file name : rtkuart.inf
09:47:31:853: Read INF file name : Intelnfc.inf
09:47:31:857: Read INF file name : gnssDriver.inf
09:47:31:861: Read INF file name : SileadTouch.inf
09:47:31:865: Read INF file name : igdlh.inf
09:47:31:870: NO BIOS File to install!
09:47:31:874: Pre-Installing Drivers...
09:47:31:880: Pre-installing driver file C:\LattePanda-Win10-Software-master\LattePanda-Win10-Software-master\Drivers\2G32GB_Drivers\All-in-one Pack\CHT T3 MRD PR2 Driver WW51.2\Installer\PlatformInstaller\Drivers\MBI\MBI.inf
09:47:31:885: E Unable to pre-install driver file : C:\LattePanda-Win10-Software-master\LattePanda-Win10-Software-master\Drivers\2G32GB_Drivers\All-in-one Pack\CHT T3 MRD PR2 Driver WW51.2\Installer\PlatformInstaller\Drivers\MBI\MBI.inf - error code : 3758096949
09:47:31:889: E Uninstalling drivers that were previously pre-installed by DriverPackagePreInstall...
09:47:31:894: E Setup aborted!
09:47:31:900: m_nCurrentIndex : 4
09:47:31:946: Showing dialog: FINISH
09:47:39:442: Dumping MSI properties (0 total)
09:47:39:450: Exit code: 1603
09:47:39:457: >>> Log End
