HuskyLens is an easy-to-use AI machine vision sensor. It is equipped with multiple functions, such as face recognition, object tracking, object recognition, line tracking, color recognition, and tag(QR code) recognition.
By jeffroig1
#43112
The huskylens seems to work well so long as the lighting condition remain the same but once the lighting changes it can no longer recognize a color or object or face. I have noticed if I turn the lights down in a room and do color recognition and then turn the lights up in the room that the image shown in the screen is extremely bright. Is there a work around for this or do I have to keep the light level in each room the same?
Thank you
Jeff
By jeffroig1
#43329
I designed a work around for this. I created a fixture that the Huskylens sits in and it has 6 High intensity LEDS around it and they are controlled via a Photoresistor. As the room light gets darker the LEDS go brighter and match the original light intensity of the room.
