$USD
  • EUR€
  • £GBP
  • $USD
PROJECTS 3D PrintingRaspberry Pi
Make a Polaroid Camera Using a Raspberry Pi
DFRobot Sep 13 2016 607
01. Model
02. Printing
I didn’t take pictures of the build process, so use you’ll have to use your imagination!
03. Use sandpaper to smooth the spray paint;
04. Install the thermal printer;
05. Load the battery and power supply module into the printer
The power part is quite tricky. After testing, I found there was insufficient power from the battery to power the thermal printer (Such power-consuming equipment!). Now as I have already started to re-modify the power supply part, the pictures below can only serve as a reference. I will change them once the final draft is finished.
(There are too many gross faults this time)
06. Install the Raspberry Pi 3 model B and fix it.
07. Install the switches and solder the wires
Here I use four tactile switches, with each represents an expected effect
08. Print the front board and decorative cover
09. Install the pilot light;
10. Install the front board into the machine body
11. Connect the switches and power cords;
12. Connect the printer;
Below are some finished photos
Below are four built-in shooting effects.
REVIEW
