Aluminum Case For Raspberry Pi B+/2B/3B
$17.90
SKU: FIT0417
Stylish aluminum case for Raspberry Pi models B+/2B/3B, featuring durability, high precision, and easy GPIO cable use. Size: 103x67x41mm, Weight: 100g.
Aluminum Case for Raspberry Pi B+/2B/3B provides a durable and visually refined enclosure designed to protect and showcase single‑board computing projects. Precision CNC‑machined aluminum construction delivers structural strength while maintaining a compact footprint suitable for desktop computing, embedded prototypes, and maker installations. Anodized surface treatment enhances corrosion resistance and long‑term durability. Accurate cutouts align with board interfaces, ensuring convenient access to ports and connectors. A grooved base structure supports clean GPIO cable routing, enabling reliable integration with expansion modules, sensors, and prototyping accessories used in electronics development and embedded systems.
Precision CNC‑Machined Aluminum Construction
This metal enclosure features high‑quality aluminum processed through CNC machining to achieve tight dimensional tolerances and clean edges. The rigid metal body offers improved durability compared with common plastic housings, protecting sensitive electronics during frequent handling or deployment in workshop environments. Anodic oxidation finishing strengthens the surface layer, improving scratch resistance and corrosion protection. The result is a robust computing enclosure that balances mechanical reliability with a premium metallic appearance suitable for engineering benches, embedded installations, and display projects.
Engineered for Multiple Raspberry Pi Generations
Mechanical dimensions and port openings align precisely with several popular single‑board computer revisions. Compatibility includes Raspberry Pi 3 model B, Raspberry Pi 2 model B, and Raspberry Pi model B+. Accurate interface alignment ensures unobstructed access to USB ports, HDMI, power connectors, and networking interfaces. Such compatibility allows a single protective enclosure to support multiple generations of embedded computing hardware frequently used in prototyping labs and educational maker environments.
GPIO‑Friendly Grooved Base Design
The bottom structure integrates dedicated grooves that simplify routing of GPIO ribbon cables and expansion wiring. This thoughtful mechanical design enables convenient connection with add‑on boards, sensor modules, and custom prototyping hardware without compromising enclosure stability. Clean cable routing improves project organization and reduces stress on connectors during long‑term operation. The enclosure therefore supports advanced hardware development workflows involving robotics control systems, IoT gateways, and electronics experimentation platforms.
Figure: Aluminum CNC case for Raspberry Pi B+/2B/3B
This aluminum computing enclosure suits embedded system development, maker workstations, and STEM laboratory environments requiring durable protection for single‑board computers. Strong mechanical shielding, convenient GPIO routing, and multi‑model compatibility make this housing suitable for robotics controllers, compact servers, IoT gateways, and educational computing platforms built around Raspberry Pi hardware.
  • CNC‑machined aluminum enclosure with anodized surface treatment
  • Compatible with Raspberry Pi 3 Model B, Raspberry Pi 2 Model B, and Raspberry Pi Model B+
  • Rigid metal structure improves durability and heat resistance
  • Precision cutouts for convenient access to board connectors
  • Grooved bottom design enables clean GPIO ribbon cable routing
  • Compact mechanical design suitable for embedded computing installations
  • Embedded Raspberry Pi computing systems
  • Robotics controller enclosures
  • IoT gateway and edge computing projects
  • Electronics prototyping and maker builds
  • STEM education laboratory platforms
  • Size: 103x67x41mm (4.06x2.64x1.61")
  • Weight: 100g
  • Aluminum Case for Raspberry Pi B+/2B/3B x1
