Gravity: Digital Water Flow Sensor For Arduino - 1/8"
$8.90
SKU: SEN0216
The sensor measures liquid flow rate, using a plastic valve, rotor, and hall effect sensor for pulse signals. Ideal for monitoring devices, needs vertical installation.
The Water Flow sensor measures the rate of a liquid flowing through it. The YF-S401 water flow sensor consists of a plastic valve body, flow rotor and hall effect sensor. It is usually used at the inlet end to detect the amount of flow. When liquid flows through the sensor, a magnetic rotor will rotate and the rate of rotation will vary with the rate of flow. The hall effect sensor will then output a pulse width signal. Connect it to a microcontroller and you can monitor multiple devices such as your coffee maker, sprinkler or anything else, and control the water flow rate to suit your needs!
Gravity: Arduino Digital Water Flow Sensor - 1/8
Note:
*A 6 mm hose is recommended
*Avoid unit contact with corrosive chemicals
*The unit must be installed vertically, tilted no more than 5 degrees
*Liquid temperature should be less than 120 C to avoid damage to unit
  • Inner Diameter: 4 mm
  • Outside diameter: 7 mm
  • Proof Water Pressure: <0.8 MPa
  • Water Flow Range: 0.3-6 L/min
  • Voltage Range: 5~12 V
  • Operating Current: 15 mA (DC 5V)
  • Insulation Resistance: >100 MΩ
  • Accuracy: ±5% (0.3-3L/min)
  • The Output Pulse High Level: >4.5 VDC (DC input voltage 5 V)
  • The Output Pulse Low Level: <0.5 VDC (DC input voltage 5 V)
  • Output Pulse Duty Ratio: 50% ± 10%
  • Water-flow Formula: 1L = 5880 square waves
  • Working Humidity Range: 35% ~ 90% RH (no frost)
  • Dimension: 58*35*26 mm/2.28*1.37*1.02 inches
  • Weight: 30g
  • Gravity - Water Flow Sensor - 1/8" x1
    SENSOR de FLUJO de AGUA, EXPLICACIÓN CLARA del funcionamiento, programación, Aplicación
    Media SENSOR de FLUJO de AGUA, EXPLICACIÓN CLARA del funcionamiento, programación, Aplicación
    Electroall
    Oct 02, 2022
    2. Pipeline Clog Detection with a Flowmeter and TinyML
    Projects 2. Pipeline Clog Detection with a Flowmeter and TinyML
    Shebin Jose Jacob
    Feb 07, 2023
    wajdi. Oct 21, 2022
    Very good as description
    MAREO.JACOBS Nov 16, 2021
    Using it for over 2 months 24/7 and still running good.
