PROJECTS Arduino
Google Chrome Dinosaur Game on Arduino 1602 LCD Keypad Shield
DFRobot Aug 18 2018 263924
*Created by brzi
A fun, little offline game "ported" to an AVR MCU.
Google Dinosaur Game on Arduino 1602 LCD Keypad Shield
Things used in this project
Hardware components:
Software apps and online services:
  • Atmel Studio 7
Story
Something that was bothering me for some time now is that I haven't made anything fun in a while, mainly because I lack good ideas for things like that. Luckily, an idea came to my mind to do this project out of nowhere, and viola, here we are.
Now, just to point out, this project was NOT written in Arduino, rathte pure AVR C code using Atmel Studio. I am using an Arduino Uno and an Uno-compatible shield, but mainly because that is the cheapest and most available thing I have with me (same goes for the keypad shield I have it for years now). So for anyone familiar with C but only worked in Arduino, about half of the code would look confusing here, but take it from someone who took to learn AVR C (by myself), it's not hard at all as I managed to adapt to it in a week (more less).
If you want use the code or just flash the firmware on the UNO board, I recommend watching this video.
For the most part, I've explained everything in the code itself, here I'm going to more explain the working principle of the code.
Hitachi HD44780 (LCD Driver) and Its 4-Bit mode
This was a bit of a strugle for a datasheet newbie, but interfacing with this IC was pretty frustrating. I ended up copying configuration bytes from this guy (thanks dude). Everything else depends on setting the bits in the upper 4 pins of the PORTD register and using EN and RS pins properly. In my implemetation the whole PORTD is wasted for communicating with the display (thus nullifying the benefits of the 4-bit mode) and effectively wasting the UART but I wans't going to use those for anything else anyway so it's ok for this use case. Make sure when you interface with this IC to use proper delays otherwise it wont be able to proccess the data properly (it is a fairly slow chip). Another point is that the game speed is limited by how quick the display can refresh. At its highest peek speed, the display updates at 11.8Hz (85ms delay on loop) and it's readable enough to play this kind of game, everything further causes major gosting and brightness issues. Now, you have to keep in mind, this isn't want the IC and display are made for, just simple text displaying.
Button Pooling
Every 500us Timer1 is set to triger TIMER1_COMPA_vect ISR where it's checked if the up button is pressed and global variable(s) is set accordingly.
Upper, Downer Buffers and Screen Drawing
To make everything easier to code and effectively shrink the application logic I use a buffer for the line one and a buffer for the line two of the display. Everything is written to those 2 buffers and they are written as a whole to the display.
Custom Characters for Dinosaur and Cactus
Nothing special here, I made a 5x8 image and drew the dinosaur and the cactus. Every colored square represents a 1 and empty (white) one represents to zero. After that I translated that to hex and added everything to the two uint8 arrays. Those 2 characters are stored in IC's CGRAM, where dinosaur is 0x00 and cactus is 0x01 in its register.
Overview of Game Characteristics
  • Game speeds up the longer you play it
  • The cactuses are initialy seperated by minimaly 5 spaces, as the game progresses it goes down to 3
  • Current score is displayed in the game, current, and best score are displayed after you lose
  • There is 500ns interrupt pooling to check if the Up button is pressed and thus there are no issues with delay blocking the input
  • Cheating by holding the Up button constantly or spaming it are prevented
  • The dinosaur is in the air 3 loop cycles after it jumps
  • Custom characters made for the cactuses and dinosaur
After you loose, press the select button to restart the game.
Code
main.c C/C++
main.c file for the project. Just create a new project and paste this in, no other dependencies (that aren't already a part of the Atmel Studio and AVR GCC)
#include
#define  F_CPU 16000000UL //Our CPU speed (16MHz)
#include  //Libraries for delay and interrupt utilities
#include
#define command 0 //explained in dispSend() function
#define write 1
uint8_t upperBuff[16] , downerBuff[16], overMsgUpper[] = "Score: ", overMsgDowner[] = "Best: ", scoremsg[] = "Score:" , din[] = {0x0E, 0x17, 0x1E, 0x1F, 0x18, 0x1F, 0x1A, 0x12}, cact[] = {0x04, 0x05, 0x15, 0x15, 0x16, 0x0C, 0x04, 0x04};
        //Buffers for line one and two. Message to display after lost game.                     //Score text during game. //Dinosaur and cactus bitmaps
uint8_t canup = 1, longhold = 0, distance = 6, speed = 200, isup = 0, dontprint = 0; //All of these are explained further
uint16_t aVal = 0, score = 1, bestscore = 0;
int i;
void dispInit();
void dispWrite(uint8_t bits);
void dispSend(uint8_t bits, uint8_t act);
void dispSetLine(uint8_t line);
void dispClear();
void dispHome();
void dispPrintChar(uint8_t chr[], uint8_t size);
uint16_t aRead();
int main(void)
	for(i = 0; i < 17; i++) downerBuff[i] = ' '; //Initialize upper and downward buffer
	for(i = 0; i < 17; i++) upperBuff[i] = ' ';
	dispInit(); //Initialize the display
	TCCR1B |= (1 << WGM12) | (1 << CS11); //Set Timer1 to compare to OCR1A and prescaler of 8
	OCR1AH = (500 >> 8); //This equals to 2000Hz or 500us timing, look for TIMER1_COMPA_vect down below
	OCR1AL = 500;
	TIMSK1 |= (1 << OCIE1A); //Enable Timer1 CompA ISR
	sei(); //Enable global interrupt
	ADMUX = (1 << REFS0); //Set AREF to VCC
	ADCSRA = (1 << ADPS2) | (1 << ADPS1) | (1 << ADPS0) | (1 << ADEN); //set ADC prescaler to 128 and enable ADC (defaulted to free running mode)
	while (1) {
		ADMUX |= (1 << MUX2) | (1 << MUX0); //Set pin from ADMUX to ADC5 (floating)
		srand(aRead()); //Use it as a random seed
		ADMUX &= ~(1 << MUX2) & ~(1 << MUX0); //Revert back to ADC0 to read the button value
		if(aRead() > 900) longhold = 0; //Reads if Up button has been released to prevent cheating. The value is so low because if you hold your fingers beneath one of the buttons the voltage would drop, this prevents the dinosaur from locking up
		for(i = 0; i < 16; i++) downerBuff[i] = downerBuff[i + 1]; //Shifts everything in downward buffer by one place to the left
		 if((rand() % 100) > (rand() % 100) && !dontprint){ //This portion decides if it should put a cactus or a blank spot, dontprint is used to prevent cactus grouping
		  downerBuff[15] = 0x01; //0x01 represents the cactus (we added cactus and dinosaur to CGRAM when we initialized the display)
		  dontprint = 1; //This part acts both as a boolean and a counter to ensure cactus separation
		 else downerBuff[15] = ' ';
		 char lastchar = downerBuff[3]; //We remember the whats initially added to the downward buffer before replacing it with the dinosaur
		 if(!isup){ //If din should be placed down
			downerBuff[3] = 0x00; //Place it down
			dispSetLine(2);
			dispPrintChar(downerBuff, sizeof(downerBuff)); //Draw it
			downerBuff[3] = lastchar; //Place back previous thing to the buffer
			canup = 1;  //This flag is used to disable dinosaur from getting up before it was drawn down, in this case he can go up
		} else { //If din should be placed up
			upperBuff[3] = 0x00; //Place it up in upper buff
			dispSetLine(1);
			dispPrintChar(upperBuff, sizeof(upperBuff));
			dispSetLine(2);
			canup = 0; //In this case he wont go up until rendered on line 2
		if(dontprint) dontprint++;
		if(dontprint > distance) dontprint = 0; //This is the part that ensures cactus separation, it will keep the cactus 3-5 spaces apart minimally (depends on the game progress)
		if(isup) isup++; //This part makes sure din is on upper side for 3 loops after he was initially drawn there
		if(isup > 4){
		 upperBuff[3] = ' ';
		 dispSetLine(1);
		 isup = 0;
		for(i = 0; i < sizeof(scoremsg); i++) upperBuff[i + 5] = scoremsg[i]; //This part prints the current score during the game
		uint8_t cnt = 11;
		for(i = 10000; i > 0; i /= 10){
			upperBuff[cnt] = ((score / i) % 10) + '0';
			cnt++;
			dispSetLine(1);
		score++; //Increment the score once on loop
		if(score > bestscore) bestscore = score; //Remember best score
		if(lastchar == 0x01 && !isup){ //Check if the dinosaur is downward and hit a cactus
			dispClear(); //Clear the display and buffers
			uint8_t cnt;
			dispSetLine(1);
			for(i = 0; i < sizeof(overMsgUpper); i++) upperBuff[i] = overMsgUpper[i]; //Display worst and best score
			cnt = sizeof(overMsgUpper) - 1;
				cnt++;
			dispSetLine(2);
			for(i = 0; i < sizeof(overMsgDowner); i++) downerBuff[i] = overMsgDowner[i];
			cnt = sizeof(overMsgDowner) - 1;
				downerBuff[cnt] = ((bestscore / i) % 10) + '0';
				cnt++;
			while(1){ //Wait for select button to be pressed
				aVal = aRead();
				if(aVal > 635 && aVal < 645){ //After that clear all the variables
					dispSetLine(1);
					dispSetLine(2);
					dontprint = 0;
					isup = 0;
					score = 1;
					speed = 200;
					longhold = 0;
					distance = 6;
					canup = 1;
					break;
        if(score % 5 == 0) speed -=2; //If score is divisible by 5 make game faster by -2ms
		if(speed < 85) speed = 85; //Minimal time in ms (+ ~2ms) that the loop will be halted for (limited by display refreshing, in my testing 11.8Hz was readable enough to be playable)
		if(score % 175 == 0) distance--; //Every time you score a number divisible by 175 minimal cactus distance gets smaller
		if(distance < 4) distance = 4;
		for(i = 0; i < speed; i++) _delay_ms(1); //This is the only way as the compiler expects a const number here
void dispInit(){
	_delay_ms(50); //Just in case
	DDRD = 0b11110000; //Set these pins to output. PD4 - PD7 correspond to D4 - D7 on display, we need to configure it to run in 4 bit mode
	DDRB = 0b00000011; //PB0 is tied to RS and PB1 to EN
	dispWrite(0x30);//*This part here is explained in Hitachi HD44780 datasheet on how to initialize the display in 4bit mode
	_delay_us(4500);//*Essentially you send the reset signal 3 times, and then set it to 4 bit mode
	dispWrite(0x30);//*
	_delay_us(4500);//*
	dispWrite(0x30);//*
	_delay_us(4500);//*
	dispWrite(0x28);//*
	dispSend(0x28, command); //Send 4bit mode function set
	dispSend(0x08, command); //Turn the display off
	dispSend(0x01, command); //Clear its RAM (if MCU resets that doesn't mean the display was reset, so we clear everything)
    _delay_ms(50);
	dispSend(0x0C, command); //Turn the display on
	_delay_ms(5);
	dispSend(0x40, command); //Tell the display we want to enter a custom character to its CGRAM (on address 0x00)
	for(i=0; i<8; i++) dispSend(din[i], write);
	dispSend(0x80, command); //Transaction end
	dispSend(0x48, command); //Same thing, but for 0x01
	for(i=0; i<8; i++) dispSend(cact[i], write);
void dispPrintChar(uint8_t chr[], uint8_t size){
	for(uint8_t i = 0; i < size; i++) dispSend(chr[i], write); //Self explanatory
void dispSetLine(uint8_t line){
	if(line == 2) dispSend(0xC0, command); //Sets the line where 0xC0 is line 2 and 0x80 is line 1
	else dispSend(0x80, command);
void dispClear(){
	dispSend(0x01, command); //Self explanatory
	_delay_ms(2); //This command takes longer for the IC to process, this delay is necessary
void dispHome(){ //This function isn't used in this application but its there for expandability, it places the cursor on the line 1 column 1
	dispSend(0x02, command); //Self explanatory
	_delay_ms(2);
void dispSend(uint8_t bits, uint8_t act){
	if(act) PORTB |= (1 << DDB0); //Set PB0 if we are writing a character, else pull it low
	else PORTB &= ~(1< 95 && aVal < 104 && canup){ //Check if Up is pressed and that din was rendered down
		 isup = 1;
		 longhold++;
