PROJECTS ArduinoGravityRaspberry PiMicroPython
Python/MicroPython Sensor Logger with Google Sheets
DFRobot Nov 28 2018 261009
This project is made by Bobby Leonard.
Wemos D1 mini takes sensor readings and sends a POST request containing data to Flask Server on RPi 3. Data is then written to Google Sheet.
Story
A system for recording sensor values to a Google Sheet. Making use of HTTP requests to communicate between the micro-controller and the server, and utilising gspread to write data to online spreadsheet.
You will need to follow the instructions on the following link to set up access to your spreadsheet.
http://gspread.readthedocs.io/en/latest/oauth2.html
pin D0 to RST: Must be connected to wake from Deepsleep.
+ : to 3.3v on Wemos
- : to GND on Wemos
Signal: to A0 on Wemos
As usual, if you need help implementing this in your own project, leave me a comment and I'll get back to you.
Hardware components
Raspberry Pi 3 Model B
Everything ESP Wemos D1 Mini
DFRobot Capacitive Soil Moisture Sensor
Google Sheets
python3
micropython
Code
import machine
import urequests
import time
rtc = machine.RTC() # Clock for deepsleep
rtc.irq(trigger=rtc.ALARM0, wake=machine.DEEPSLEEP)
adc = machine.ADC(0) # Pin to Read sensor voltage
# Sensor calibration #
# values on right are inverse * 1000 values on left
# dry air = 759 (0%) = 1.31752305665349143610013175231
# water = 382 (100%) = 2.61780104712041884816753926702
# The Difference     = 1.30027799046692741206740751471
# 1 %                = 0.0130027799046692741206740751471
hours = str(time.localtime()[3])
mins = str(time.localtime()[4])
secs = str(time.localtime()[5])
if int(secs) < 10:
	secs = '0' + secs
if int(mins) < 10:
	mins = '0' + mins
timestr = hours + ':' + mins + ':' + secs
variable = (((1 / adc.read())* 1000) / 0.0130027799046692741206740751471) - 101
if variable > 100:
	variable = 100
if variable < 0:
	variable = 0
url = 'http://192.168.1.2:8000/solomon'
headers = {'content-type': 'application/json'}
data = '{"Value": "%s", "Time": "%s"}' % (variable, timestr)
resp = urequests.post(url, data=data, headers=headers) # Send the request
print(resp.json())
rtc.alarm(rtc.ALARM0, 25000) # Set alarm for 25 seconds
machine.deepsleep() # Go to sleep ...
