NEWS HUSKYLENS
HuskyLens – An AI Camera: Click, Learn, and Play!
DFRobot Jul 24 2019 264341
AI camera-HuskeyLens has started crowdfunding, it belongs to you!
Click here, learn more about crowdfunding information
(Reward: HuskeyLens)
Note: Kickstarter campaign has ended. You can order HUSKYLENS right now!
HuskyLens is an easy-to-use AI camera. It can learn to detect objects, faces, and colors just by clicking. The more it learns, the smarter it is. The adoption of the new generation AI chip allows HuskyLens to detect faces at 30 frames per second. HuskyLens can connect to Arduino, Raspberry Pi, LattePanda, or micro:bit, and make your very creative projects without playing with complex algorithms.
HuskyLens aims to be the simplest AI camera. It already has many types of image processing algorithms built in. You are able to change various algorithms by pressing buttons, and it can learn new objects from images and detect them. Additionally, HuskyLens carries a 2.0 inch display, what you see is what you get!
HuskyLens is designed to be smart. Built-in algorithms allow HuskyLens to learn new objects, faces, and colors through a single click. Moreover, by long pressing, HuskyLens can continually learn them even from different perspectives and in various ranges. The more it learns, the more accurate it can be.
Aside from the various built-in algorithms, what truly amaze is that HuskyLens can run these algorithms simultaneously. For example, line tracking algorithm and tag recognition algorithm can be activated at same time, allowing your small robot to not only follow a line, but also determine which directions to turn.
HuskyLens adopts a new generation AI specialized chip Kendryte K210. It is powered by 400MHz dual core RISC-V 64bit processor, the performance of this special AI chip offers 1,000 times faster than that of the STM32H743 when running neural network algorithm.
Classic YOLO artificial intelligence algorithm can only be running at 1~2 frames per second with the STM32H743, while the HuskyLens delivers up to 30x increase. Its performance is exceptionally high and is suitable for application of capturing quickly moving objects.
Through the UART port, HuskyLens can be easily connected to mainstream microcontroller such as Arduino, LattePanda, Raspberry Pi and micro:bit.
HuskyLens is upgradeable. New firmware will be continuously provided to improve HuskyLens, make it smarter and more reliable.
With the HuskyLens, your projects have new ways to interact with you or environment, such as interactive gesture control, autonomous robots, smart access control and interactive toy. There are so many new applications for you to explore.
HuskyLens can learn specific hand gestures, it recognizes learned hand movement patterns and feed its position. With these data, creating awesome interactive projects are never so easy.
HuskyLens can detect and follow lines. Line-following is not something new, there are plenty of methods and algorithms having excellent performance in this application. However, most of them require tedious parameters tuning. HuskyLens provides a new way to do line following, by simply clicking buttons, new lines can be learned and followed.
When combined with tag recognitions, HuskyLens will automatically determine proper direction, and allow you to enjoy creating a self-driving robot.
HuskyLens can be eyes of robots. It allows your robot to recognize you, understand your hand gesture commands, help you organize your things… anything is possible.
When using HuskyLens, pan tilt servo can be rigged to enhance your new camera. The HuskyLens can then allow your camera to automatically follow and capture moving people or objects without losing any detail.
