PROJECTS Arduino
Talking Smart Glass for the Blind
DFRobot Sep 01 2019 260211
Things used in this project
Hardware components
Ultrasonic Sensor - HC-SR04 (Generic) ×3
DFRobot DF Player mini ×1
SparkFun Arduino Pro Mini 328 - 5V/16MHz ×1
PCBWay Custom PCB ×1
Custom PCB (JLCPCB) ×1
3.5mm Audio jack ×1
Vibration motor ×1
Slide Switch ×1
Arduino IDE
Soldering iron (generic)
Plier
Story
There are multiple smart accessories such as smart glasses, smartwatches, etc. available in the market. But all of them are built for us. There is a significant lack of technology to aid the physically challenged. I wanted to build something that is useful for the visually challenged people. So I designed low cost smart glass that can be used to help the visually impaired.
This project uses a few ultrasonic distance sensors, an Arduino Pro Mini, an MP3 player module, and some vibration motors.
The circuit board used in this project is designed in the form of a spectacle, which can be worn by a visually impaired person. An Arduino mounted on the spectacle will detect the obstacle with the help of the sensors and notify the user through headphones and vibration motors.
Flash the Pro Mini
Connect the Pro Mini to the computer using FTDI cable.
Select proper COM port.
Select 'Arduino Pro or Pro Mini.'
Click upload
Make sure to flash Arduino before soldering it to PCB. Once all the components are soldered, it will be bit harder to connect the programming header.
Assembling the PCB
Solder the components like Arduino, DF Player, Audio jack, Slide Switches to the PCB first.
We can't directly solder the HC-SR04 module available from market. some modification need to be done.
Straighten the male header using a pliers or de-solder the 90° headers and solder normal headers.
Add electrical tape to tha back of HC-SR04 to avoid short circuit.
Insert HC-SR04 to designated solder pads. hold the left and right HC-SR04 at an angle and apply solder.
Solder rest of the components such as power supply cable, slide switches, vibration motors etc.
Copying Audio Files to the SD card
Copy content of the Audio files folder to the root of the SD card.
Copy folders (01, 02, 03) itself, not its content.
SD Card file structure
Schematics
The circuit diagram
Code
Talking Smart Glass For Blind
B45i / Talking-Smart-Glass-For-Blind
Read More
Download as zip
This article copied from hackster.io, Author: Amal Shajan
