| Technology | Advantages | Disadvantages | Positioning Accuracy | Cost |
| Wi-Fi | Widely used, broad coverage | Prone to interference, lower accuracy | 5-15 meters | Medium |
| Bluetooth | Low power consumption, widespread devices | Limited coverage range | 1-10 meters | Low |
| RFID | Low cost, simple deployment | Requires tags, highly affected by the environment | 1-10 meters | Low |
| UWB | High precision, strong anti-interference | High cost, devices not widespread | 10-30 centimeters | High |
| Geomagnetic | No extra hardware needed, uses phone sensors | Susceptible to magnetic interference, lower accuracy | 1-2 meters | Low |
Figure:Wi-Fi Positioning
Case Study: Wi-Fi Positioning Navigation Technology in Shopping Malls
Advantages and Disadvantages:
Advantages:
Disadvantages:
Application Areas:
Figure: BLE and Beacon
Common methods of Bluetooth positioning include:
Case Study: Bluetooth Beacon Navigation System in Shopping Malls
Advantages:
Disadvantages:
Application Areas:
RFID Indoor Positioning
Case Study: RFID Technology in Retail and Library Management
Advantages:
Disadvantages:
Application Areas:
Case Study: Apple's AirTag with UWB Technology
Advantages:
Disadvantages:
Application Areas:
Figure: Indoor positioning
Advantages:
Disadvantages:
Application Areas:
