PROJECTS Arduino
How to Make an Arduino RGB Color Grab Flashlight (Part 2)
DFRobot Sep 17 2019 259711
Part 1 Link: How to Make an Arduino RGB Color Grab Flashlight (Part 1)
Install
1.Fix the color sensor to the back cover with the quick-drying glue temporarily.
2.Fix the battery to the slot in the back cover with the hot-melt adhesive
3.Fix the light cover with the quick-drying glue to the holes reserved in the crust
4.Install the masking cap
5.Fix Beetle with hot-melt adhesive to the crust bottom board.
6.Stick the DC-DC module to the top left of the inner wall with hot-melt adhesive.
7.Put the RGB LED to the slot in the back of the light cover
8.Put all wires to the inner part of the crust. Take off the black acrylic crust, expand the hole size and drill a slope to suit the screw.
9.Install 2 self-tapping screws.
Here we finish all work to install.
Uploading the program
Please kindly note that in the end of the program burning, it will not show “successful loading”, but will remind cannot find the serial port, never mind, it shows that the uploading is done. If you need to upload it again, Beetle should be short circuited, otherwise IDE will not recognize the main control board.
Done with the uploading
Here we accomplished all works to make a color recognize flashlight.
