NEWS IoT
FireBeetle 2 ESP32-C6: The Ultimate Controller for Your Smart Home Projects
DFRobot Jul 02 2024 268579
The FireBeetle 2 ESP32-C6 is a versatile, low-power IoT controller board designed for smart home automation, control, and monitoring systems. Supporting multiple communication protocols, including Wi-Fi 6, Bluetooth 5, Zigbee 3.0, and Thread 1.3, it serves as the perfect hub for all your smart home needs.
Start your smart home projects for just $5.90!
Project 1. Smart Planter Monitoring
Create a sustainable, low-power balcony plant monitoring system with the FireBeetle 2 ESP32-C6. This project monitors soil moisture in real-time and transmits data wirelessly for remote monitoring and alerts.
This project covers hardware selection, circuit design, software development, and data analysis to help you efficiently care for your plants.
View Detailed Tutorial
FireBeetle 2 ESP32-C6 Smart Planter Monitoring Project
Add these items to your cart to start building:
Project 2. Home Temperature, Humidity, and Air Quality Monitoring
Build an efficient and cost-effective indoor air quality monitoring system using the FireBeetle 2 ESP32-C6. This project guides you through the steps to monitor temperature, humidity, and air quality (including AQI, VOCs, and eCO2) in real-time using open-source hardware.
FireBeetle 2 ESP32-C6 Home Temperature, Humidity, and Air Quality Monitoring Project
Recommend Accessories
Product Name
Fermion: 1.8" 128x160 IPS TFT LCD Display with MicroSD Card Slot (Breakout)
Jumper Wires 9" F/F (10 Pack)
Medium Bread Board Self Adhsive
Gravity: F/F DuPont Line with Tag (30cm, 5 Pack)
Gravity: 4PIN M/M DuPont Line with Tag (30cm, 5 Pack)
Figure
SKU
DFR0928
FIT0030
FIT0009
FIT0916-FF
FIT0916-MM
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Project Expansion
Take advantage of the onboard GDI interface for easy screen connections, ensuring efficient data visualization. Our detailed screen lists and configuration tutorials help integrate ESP32-C6 functionalities seamlessly into any setup.
All DFRobot's Gravity and Fermion series sensors are compatible with the FireBeetle 2 ESP32-C6, offering a comprehensive selection for various projects.
Start your smart home journey today with the FireBeetle 2 ESP32-C6 and our wide range of compatible accessories!
More Tutorials
The FireBeetle 2 ESP32-C6 can be configured and programmed using Arduino IDE or MicroPython. Detailed tutorials are provided, making the setup process smoother.
These tutorials cover basic setup, including
Advanced tutorials are also available for project development, including
Find the Right Controller for Your Smart Home Projects
If you have previously purchased a FireBeetle ESP32 series controller and are unsure about the differences between the C6 and other products, or if your smart home project has specific requirements that the FireBeetle ESP32 C6 cannot meet, we offer a variety of different FireBeetle ESP32 series controllers. For more information, check out our detailed comparison guide to help you choose the most suitable controller for your project needs.
