The FireBeetle 2 ESP32-C6 is a versatile, low-power IoT controller board designed for smart home automation, control, and monitoring systems. Supporting multiple communication protocols, including Wi-Fi 6, Bluetooth 5, Zigbee 3.0, and Thread 1.3, it serves as the perfect hub for all your smart home needs.
Start your smart home projects for just $5.90!
FireBeetle 2 ESP32-C6 IoT Development Board for Smart Home Control System
Supports Wi-Fi 6, Bluetooth 5, Zigbee 3.0, and Thread 1.3
SKU: DFR1075
Create a sustainable, low-power balcony plant monitoring system with the FireBeetle 2 ESP32-C6. This project monitors soil moisture in real-time and transmits data wirelessly for remote monitoring and alerts.
This project covers hardware selection, circuit design, software development, and data analysis to help you efficiently care for your plants.
Add these items to your cart to start building:
Product Name
Figure
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Product Name
Fermion: 1.8" 128x160 IPS TFT LCD Display with MicroSD Card Slot (Breakout)
Figure
.jpg)
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Build an efficient and cost-effective indoor air quality monitoring system using the FireBeetle 2 ESP32-C6. This project guides you through the steps to monitor temperature, humidity, and air quality (including AQI, VOCs, and eCO2) in real-time using open-source hardware.
Product Name
Fermion: SHT31 Digital Temperature & Humidity Sensor (Breakout)
Figure
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Product Name
Gravity: F/F DuPont Line with Tag (30cm, 5 Pack)
Gravity: 4PIN M/M DuPont Line with Tag (30cm, 5 Pack)
Figure
.jpg)
SKU
DFR0928
FIT0030
FIT0009
FIT0916-FF
FIT0916-MM
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Take advantage of the onboard GDI interface for easy screen connections, ensuring efficient data visualization. Our detailed screen lists and configuration tutorials help integrate ESP32-C6 functionalities seamlessly into any setup.
All DFRobot's Gravity and Fermion series sensors are compatible with the FireBeetle 2 ESP32-C6, offering a comprehensive selection for various projects.
Start your smart home journey today with the FireBeetle 2 ESP32-C6 and our wide range of compatible accessories!
The FireBeetle 2 ESP32-C6 can be configured and programmed using Arduino IDE or MicroPython. Detailed tutorials are provided, making the setup process smoother.
These tutorials cover basic setup, including
Advanced tutorials are also available for project development, including
If you have previously purchased a FireBeetle ESP32 series controller and are unsure about the differences between the C6 and other products, or if your smart home project has specific requirements that the FireBeetle ESP32 C6 cannot meet, we offer a variety of different FireBeetle ESP32 series controllers. For more information, check out our detailed comparison guide to help you choose the most suitable controller for your project needs.
