PROJECTS Arduino
Soil Moisture Sensor With Watering Warning
DFRobot Dec 19 2019 259987
We are creating a device that measures soil moisture, based on a WEMOS D1 mini and a Capacitive Soil Moisture sensor.
With cloud integration the measurement of the sensor sent to the IoT Guru Cloud, where we get fancy graphs and we can set a warning that we need to watering the plant.
Supplies:
WEMOS D1 mini
Step 1: Connection of the Hardware
The Capacivite Soil Moisture sensor has three pin:
1. Ground
2. Vcc
3. Analog output
You can connect this pins to the WEMOS D1 mini in same order:
1. D5
2. D0
3. A0
Step 2: Arduino Source Code
The source code is contains an IoT Guru Cloud integration, you can check out our Tutorials about the integration. You will need:
userShortId
deviceShortId
deviceKey
nodeShortId
fieldName
The code will send an analog measurement in every one minute.
Click Here to Download soil_moisture.ino
Step 3: Check the Graph in Your Account
If your device can connect and can send data, you will be see something like this:
https://iotguru.live/field/9e8df7a0-f01e-11e9-a95e-071b2aa4809f/analog
Step 4: Watering Warning
You can set range alert and the IoT Guru Cloud will be alert you whenever the measurement is less than the minimum or greater than the maximum.
This project copied from instructables.com, Project Maker: iotgurulive
