PROJECTS IoTArduinoESP8266
Landslide Detector Based on Internet of Things
DFRobot Jan 02 2020 262400
This project can detect both possible and actual landslides, and send an alert to all those who are connected.
Things used in this project
Hardware components
Arduino UNO & Genuino UNO ×2
NodeMCU ESP8266 Breakout Board ×1
SparkFun Soil Moisture Sensor (with Screw Terminals) ×1
Seeed Grove - Vibration Sensor (SW-420) ×1
SparkFun Ultrasonic Sensor - HC-SR04 ×1
Adafruit Standard LCD - 16x2 White on Blue ×1
HC-12 SI4463 ×2
DFRobot I2C 16x2 Arduino LCD Display Module ×1
Buzzer ×1
Blynk
Story
To join an Internet of Things National Competition in Indonesia, i with my team looking for a solution using the Internet of Things. Then we decided to make this thing, a landslide detector based on the IoT.
We are using Blynk in this project to connect between this detector and an Android device
In this project, I used at least two devices.
The first device is an Arduino Uno R3 that will gather the data from all sensor reading. Then all the data will be sent to the second device using an HC-12 module.
The second set of devices that I used was a NodeMCU ESP8266 and Arduino Nano. This setup will receive the data from the first device using HC-12 module controlled by Arduino Nano, and the received data sent by Arduino Uno to NodeMCU trough Serial communication. Then the data that receive by NodeMCU will be sent to Blynk database from WiFi network that can be accessed with us.
Why use Arduino Uno, not directly connect HC-12 to NodeMCU ESP8266?
Since our team got a trouble when using HC-12 with NodeMCU, and we decided to try to transit the data first to Arduino Uno and send it to NodeMCU via serial communication, and the good news is it works. At least it solve our problem.
I hope this project helps you. If you have any suggestion or better solution for our problem, send it on the comment space. Happy learning!
Schematics
Code
Arduino 1 | First Device Arduino
//HC-12 Library #include <SoftwareSerial.h> SoftwareSerial HC12(10,11); //hc12 tx, hc12 rx //Ultrasonic Sensor const int trigPin = 4; const int echoPin = 5; long duration; int distanceCm; //Vibrate Sensor int vib = 6; int val; int getar = 0; void setup() {  //All Device Begin  Serial.begin(9600);  HC12.begin(9600);  //Ultrasonic pin configuration  pinMode(trigPin, OUTPUT);  pinMode(echoPin, INPUT);  //Soil Moisture + Vibrate Sensor pin Confuguration  pinMode(A0, INPUT);  pinMode (vib, INPUT); } void loop() {  float sensorValue = analogRead(A0);  float persen=((1024-sensorValue)/1024)*100;  Serial.println(persen);  HC12.println(persen);  delay(500);    distanceCm= duration*0.034/2;  int getar= digitalRead(vib);    digitalWrite(trigPin, LOW);  delayMicroseconds(2);    digitalWrite(trigPin, HIGH);  delayMicroseconds(10);    digitalWrite(trigPin, LOW);  duration = pulseIn(echoPin, HIGH);   //aman dan waspada  if (getar == 1 && distanceCm >= 5)  {    if (persen >= 0 && persen <= 85)    {      Serial.println("Aman");      HC12.println(1100); //aman      delay(500);    }    else if (persen >= 85 && persen <= 90)    {      Serial.println("Waspada");      HC12.println(1110); //waspada      delay(500);    }    else if (persen >= 90 && persen <= 100)    {      Serial.println("Bahaya");      HC12.println(1101); //waspada      delay(500);    }  } //bahaya  else if (getar == 0 && distanceCm <= 5 )  {    if (persen >= 0 && persen <= 100)    {      Serial.println("Bahaya");      HC12.println(1101); //bahaya      delay(500);    }  }  else if (distanceCm <= 5)  {    Serial.println("Bahaya");    HC12.println(1101);    delay(500);  }  delay(100);   }
Arduino 2 | Second Device Arduino
#include <SoftwareSerial.h> #include <LiquidCrystal_I2C.h> LiquidCrystal_I2C lcd(0x3F, 16, 2); SoftwareSerial HC12(10, 11); // HC-12 TX Pin, HC-12 RX Pin int O_aman = 7; int O_waspada = 8; int O_bahaya = 9; int buzzer = 12; void setup(){  Serial.begin(9600);  HC12.begin(9600);  pinMode(buzzer, OUTPUT);  pinMode(O_aman, OUTPUT);  pinMode(O_waspada, OUTPUT);  pinMode(O_bahaya, OUTPUT);  lcd.begin();  lcd.setCursor(0,0);  lcd.print("     SISTEM");  lcd.setCursor(0,1);  lcd.print("   PERINGATAN");  delay(1000);  lcd.clear();  lcd.setCursor(0,0);  lcd.print(" BAHAYA LONGSOR");  lcd.setCursor(0,1);  lcd.print("    POLINEMA");  delay(1000);  lcd.clear();  lcd.setCursor(0,0);  lcd.print("SCANNING");  delay(500);  lcd.setCursor(0,0);  lcd.print("SCANNING.");  delay(500);  lcd.setCursor(0,0);  lcd.print("SCANNING..");  delay(500);  lcd.setCursor(0,0);  lcd.print("SCANNING...");  delay(500);  lcd.clear();  lcd.setCursor(0,0);  lcd.print("SCANNING.");  delay(500);  lcd.setCursor(0,0);  lcd.print("SCANNING..");  delay(500);  lcd.setCursor(0,0);  lcd.print("SCANNING...");  delay(1000);  lcd.clear();  lcd.setCursor(0,0);   } void loop() {  if(HC12.available() >1){    int input = HC12.parseInt();    //float soil = HC12.read();      //aman    if(input == 1100)    {      Serial.println("2");      lcd.clear();      lcd.print("STATUS : AMAN");      delay(1000);    }    else    {      Serial.println("1");    }    //waspada    if(input == 1110)    {      Serial.println("4");      lcd.clear();      lcd.print("STATUS : WASPADA");      digitalWrite(buzzer, HIGH);      delay(200);      lcd.clear();      lcd.print("STATUS : WASPADA");      digitalWrite(buzzer, LOW);      delay(200);    }    else    {      Serial.println("3");    }    //bahaya    if(input == 1101)    {      Serial.println("6");      lcd.clear();      lcd.print("STATUS : BAHAYA");      digitalWrite(buzzer, HIGH);      delay(500);      lcd.clear();      lcd.print("STATUS : BAHAYA");      digitalWrite(buzzer, LOW);      delay(500);    }    else    {      Serial.println("5");    }  }  HC12.flush();  delay(20); }
NodeMCU | Second Device Arduino
//Blynk Library #define BLYNK_PRINT Serial #include <ESP8266WiFi.h> #include <BlynkSimpleEsp8266.h> //Blynk Timer Configuration BlynkTimer timer; //LED pin definition #define led_aman 4 //D2 #define led_waspada 0 //D3 #define led_bahaya 2 //D4 #define BLYNK_PRINT Serial //Wifi Configuration char auth[] = "XXXXXXXXXXXXXXXX"; //Blynk Auth char ssid[] = "XXXXXXXXXXXXXXXX"; //Wifi SSID char pass[] = "XXXXXXXXXXXXXXXX"; //Wifi Pass int flag=0; //LED Widget Configuration WidgetLED led1(V1); //aman WidgetLED led2(V2); //waspada WidgetLED led3(V3); //bahaya void setup() {  //All Device begin  Blynk.begin(auth, ssid, pass);  Serial.begin(9600);  Blynk.run();  timer.run();  pinMode(led_aman,OUTPUT);  pinMode(led_waspada,OUTPUT);  pinMode(led_bahaya,OUTPUT); } void loop() {  if(Serial.available()>0)  {    int data = Serial.read();      if(data=='1')        {          digitalWrite(led_aman,LOW);          led1.off();          delay(500);        }      else if(data=='2')        {          digitalWrite(led_aman,HIGH);          led1.on();          delay(500);        }      else if(data=='3')        {          digitalWrite(led_waspada,LOW);          led2.off();          delay(500);        }      else if(data=='4')        {          digitalWrite(led_waspada,HIGH);          led2.on();          delay(500);          Blynk.notify("Kondisi Waspada");        }       else if(data=='5')        {          digitalWrite(led_bahaya,LOW);          led3.off();          delay(500);        }        else if(data=='6')        {          digitalWrite(led_bahaya,HIGH);          led3.on();          delay(1000);          Blynk.notify("Kondisi Bahaya");        }  } }
