SELECTION GUIDE DFRobotEnglishSolar
Beetle Controller Selection Guide
DFRobot Mar 30 2022 264885
DFRobot's Beetle Series controllers are a testament to innovation, offering a range of microcontrollers that cater to various project needs. From the ESP32-based IoT powerhouses to the ATmega32U4 and Atmega328p-based boards, these controllers are designed with flexibility and functionality in mind. Whether you're working on smart wearables, home automation, or remote monitoring equipment, the Beetle Series has a solution for you. The Beetle ESP32-C3 with its RISC-V processor and the compact ESP32-C6 with Wi-Fi 6 and Bluetooth 5 stand out for their high-performance capabilities. For Arduino enthusiasts, the Beetle Board and Beetle BLE offer compatibility with Arduino Leonardo, making them ideal for a wide array of DIY projects.
Applications:
  • Smart wearable devices
  • Home automation systems
  • Remote monitoring equipment
  • Health monitoring devices
  • Wireless sensor networks
  • DIY Arduino projects
Beetle Controller Selection Guide (ESP32 Series)
Product Name
Beetle ESP32 - C3 (RISC-V Core Development Board)
Beetle ESP32 Microcontroller
Beetle ESP32 C6 Mini Development Board for Wireless Smart Wearable Device (Supports BLE, Battery Charging)
Figure
SKU
DFR0868
DFR0575
DFR1117
Microcontroller
ESP32-C3-MINI-1U
ESP-WROOM-32D
ESP32-C6
CPU Frequency
160MHz
240MHz
160MHz
SRAM
400KB 8KB RTC SRAM
520KB
512KB
ROM
384KB
448KB
320KB
Flash
4MB
16MB
4MB
IO Pins
13
12
13
Analog Input
6
4
4
UART
2
1
3
I2C
1
1
2
USB Socket
Type-C
Micro USB
Type-C
Dimension
25*20.5mm
35*34mm
25*20.5mm
Beetle ESP32-C3 is a RISC-V processor-based controller that supports Bluetooth and WiFi. The integrated Lithium battery charging management makes it convenient to use with Li-ion battery. The supported expansion board allows it to be easily connected to a screen or peripherals.
This Beetle-ESP32 is a simplified version of FireBeetle-ESP32 that supports Bluetooth and WiFi and integrates 16MB Flash and a dual-core processor.
Beetle ESP32-C6 is a compact IoT development board based on the ESP32-C6 chip, supporting Wi-Fi 6, Bluetooth 5, Zigbee 3.0, Matter, and Thread 1.3. It integrates lithium battery charging management, making it ideal for wearable applications. It supports Matter terminal device creation and has ultra-low power consumption, with deep sleep current at 14uA.
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Beetle Controller Selection Guide (Other Microcontrollers)
Product Name
DFRobot Beetle Board - Compatible with Arduino Leonardo - ATmega32U4
Beetle CM-32U4 - Compatible with Arduino Leonardo - ATmega32U4
DFRobot Beetle BLE - The Smallest Board Based on Arduino Uno with Bluetooth 4.0
Figure
SKU
DFR0282
DFR0816
DFR0339
Microcontroller
ATmega32u4
ATmega32u4
Atmega328p
CPU Frequency
16MHz
16MHz
16MHz
SRAM
2.5KB
2.5KB
2KB
ROM
1KB
1KB
1KB
Flash
32KB
32KB
32KB
IO Pins
10
11
12
Analog Input
5
2
4
UART
1
1
1
I2C
1
1
1
USB Socket
Micro USB
Type-C
Micro USB
Dimension
20*22mm
22*20.5mm
28.8*33.1mm
Beetle is a low-cost micro Leonardo controller for electronics enthusiasts. It has V-shaped large-size IO ports that are very suitable for wearable projects.
Beetle CM-32U4 is the upgraded version of Beetle. It is optimized in layout and integrates Lithium battery charging management, making it extremely suitable for battery-powered projects.
Bluno Beetle is an Arduino controller with Bluetooth 4.0. It is fully compatible with the Bluno series.
Add to Cart
Add to Cart
Add to Cart
Add to Cart
