SELECTION GUIDE
What Devices can be used as Lorawan Gateway?
DFRobot May 06 2023 266691
When choosing a LoRaWAN gateway, it is important to consider your specific network needs. LoRaWAN gateways are divided into two main categories based on the number of channels they address: single-channel gateways and multi-channel gateways.
Multi-channel gateways can receive multiple wireless channels and spreading factors simultaneously, making them more suitable for complex and scalable projects.
Single-channel gateways are cheaper and more suitable for limited network needs because they can only receive wireless signals from a specific radio channel with a specific spreading factor at a time.
If you only need a single-channel gateway and don't want to spend too much money, the following devices can be used as LoRa gateways. They can all be used as IoT gateways to connect various devices, have rich GPIO and general interfaces, and can connect various sensors and actuators.
Raspberry Pi:
You can build a single-channel LoRaWAN gateway using a Raspberry Pi and LoRa shield to report sensor data to a remote location. In this gateway, the Raspberry Pi acts as a receiver/client, while the LoRa shield acts as a transmitter/server.
Raspberry Pi connected with LoRa shield
Figure: Raspberry Pi connected with LoRa shield
LattePanda:
LattePanda 3 Delta is an x86 SBC with an Intel Core N5105 dual-core processor that can run Windows 10 and Linux. It can be used as a LoRaWAN gateway to send sensor data to the cloud.
LattePanda 3 Delta 864 Features
Figure: LattePanda 3 Delta 864
Arduino:
Arduino MKR WAN 1300 and Arduino MKR WAN 1310 are two Arduino devices with LoRa® connectivity that can be used as nodes or gateways in a LoRaWAN network.
You can configure LoRaWAN devices in the Arduino Cloud, register for The Things Console account, create a simple test program to view data from the device, and send data from the Arduino Cloud to the device.
Configuring LoRaWAN® devices in the Arduino Cloud
Figure: Configuring LoRaWAN® devices in the Arduino Cloud
BeagleBone Black:
BeagleBone Black Wireless single-board Linux computers can be used in conjunction with Long Range (LoRa) transceivers to send and receive messages in a mesh network, with one transmission/reception node acting as a relay in the system.
Figure: BeagleBone Black
Intel Edison:
Intel Edison can be connected to LoRaWAN by adding a LoraWAN module. The Intel Edison can also be connected to WiFi by adding a WiFi module. This makes Intel Edison a very flexible IoT gateway that can connect to a variety of devices and protocols.
Connect LoRa Mote to the USB host port of Edison
Figure: Connect LoRa Mote to the USB host port of Edison
NVIDIA Jetson Nano:
NVIDIA Jetson Nano Developer Kit can be used for IoT applications, including entry-level network video recorders (NVRs), home robots, and intelligent gateways with comprehensive analysis capabilities. It can be used as an application of the LoraWAN gateway to upload sensor data to the cloud, realizing remote monitoring and control.
Figure: NVIDIA Jetson Nano Developer Kit
