REVIEWS
Full Data Access Mode for Your Smart Home: Extracting Speed, Energy, and Direction from $8.9 mmWave Sensor
DFRobot Apr 15 2026 1431
Most smart home motion sensors are "blind." They only tell you one thing: Occupied or Clear.
But what if your sensor could tell you how fast a person is moving? Which direction they are walking? And even the signal energy of their presence—whether they are walking or sitting completely still?
This isn't sci-fi. It's the full data stream hidden inside the DFRobot C4002 mmWave Radar Module. While consumer sensors (like Aqara or Hue) hide this raw data behind a simple app interface, the C4002 gives developers full access via UART.
Here is how you can unlock this advanced data to build automations that PIR sensors can only dream of.
The Comparison: Why "Raw Data" Matters
Why choose a DIY module over a finished product? It comes down to Data Granularity vs. Convenience.
FeaturePIR Sensor ($10+)Consumer mmWave ($60 - $80)DFRobot C4002 ($8.90 + ESP32)
Core TechInfrared (Heat)24Gz~60GHz Radar24GHz Radar
OutputHigh / LowZone Presence (App Encrypted)Speed, Energy, Direction, Distance (UART Open)
Static DetectionNoYesYes (Up to 10m)
Data AccessNoneClosed EcosystemFull Raw Access
Total Cost~$15$60 ~ $80~$15 - $20 (Module + ESP32)
Unlocking "Advanced Sensor Control": The Raw Data Stream
According to the official DFRobot Wiki, the C4002 outputs a rich structure of data. Let's look at the actual code (getAllResults.ino) to see what's possible.
1. Motion Speed (Detecting Urgency)
Most sensors can't tell the difference between a leisurely walk and a sprint. The C4002 can.
The Code Evidence:
The "God Mode" Automation:
// Source: DFRobot_C4002 Library
Serial.print("Motion speed: ");
Serial.print(motionTarget.speed);
Serial.println(" m/s");
Safety Monitoring: If speed > 1.5 m/s inside an elderly person's room, it might indicate a fall or an emergency. Trigger an alert immediately.
Lighting Logic: If speed < 0.5 m/s (slow walking), fade the lights on slowly. If speed > 1.0 m/s (fast walking), snap the lights on instantly to prevent accidents.
(*Note: The speed threshold should be calibrated based on the actual environment. You can use the Serial Monitor to observe the speed values during normal walking and use them as a baseline.)
2. Motion Direction (Intent Detection)
Knowing where someone is going is the holy grail of automation. The C4002 classifies motion into three states: Approaching, Away, and No Direction.
The Code Evidence:
if (motionTarget.direction == eAway) {
  Serial.println("Away!");
} else if (motionTarget.direction == eApproaching) {
  Serial.println("Approaching!");
The "Welcome Home" Effect: If the sensor detects Approaching near the entryway, brighten the lights before the person even fully enters the room.
Smart Energy Saving: If the sensor detects Away (walking towards the exit), start a short countdown to turn off the HVAC, rather than waiting for a standard 5-minute timeout.
3.Dual Energy Output (Motion vs. Static)
PIR sensors stop working when you sit still. The C4002 tracks TWO separate energy levels: one for large movements (walking) and one for micro-movements (such as subtle body motion during rest).
The Code Evidence:
Serial.print("Motion energy: ");
Serial.println(motionTarget.energy);
True Sleep/Reading Detection: If "Motion Energy" drops to 0, but "Presence Energy" stays active (e.g., Energy = 5), the system knows the room isn't empty—you are just reading a book or sleeping. No more waving your arms to turn the lights back on.
Installation Debugging: Unlike PIR sensors where you guess the coverage, the live energy numbers help you find the perfect mounting spot. Check the Presence energy from the edge of your bed to ensure it accurately detects your breathing. It turns installation into a science.
System Architecture
How does this data get to your Home Assistant?
[ C4002 Module ] --(UART)--> [ FireBeetle ESP32 ] --(WiFi/ESPHome)--> [ Home Assistant ]
Sensors Raw Data                Parses Data                        Automations
(Speed/Dir/Energy)           (Text/Number Sensors)                (Lights/Alerts)
Speed, Energy, Direction, Distance  Data from C4002 mmWave Sensor
Integration: The Native ESPHome Way
For Home Assistant users, you don't even need to write C++ code. The C4002 has native ESPHome support via UART. Here is a simplified configuration snippet to get you started:
# UART Configuration
uart:
  tx_pin: GPIO25
  rx_pin: GPIO26
  baud_rate: 115200
# External components
external_components:
  - source:
      type: git   # Source
      url: https://github.com/cdjq/esphome.git   # Must be the root directory
      ref: dev   # Branch
    components:
      dfrobot_c4002  # Component
# C4002 Component Configuration
dfrobot_c4002:
# Sensor Configuration Section
sensor:
  - platform: dfrobot_c4002
    c4002_id: my_c4002
    movement_distance:
      name: "Motion Distance"
      id: movement_distance_sensor  # Motion distance
    existing_distance:
      name: "Presence Distance"
      id: existing_distance_sensor  # Presence distance
    movement_speed:
    movement_direction:
      name: "Motion Direction"
      id: movement_direction_sensor  # Motion direction
      internal: true
    target_status:
      internal: true
text_sensor:
  - platform: template
    name: "Movement Direction"
    icon: "mdi:directions"
    lambda: |-
      int d = id(movement_direction_sensor).state;
      if (d == 0) return {"Approaching"};
      else if (d == 1) return {"No Direction"};
      else if (d == 2) return {"Away"};
      else return {"Unknown"};
    update_interval: 1s
    icon: "mdi:human-greeting"
    lambda: |-
      int d = id(target_status_sensor).state;
      if (d == 0) return {"No Target"};
      else if (d == 1) return {"Static Presence"};
      else if (d == 2) return {"Motion"};
    update_interval: 0.5s
    c4002_id: my_c4002
    c4002_text_sensor:
      icon: "mdi:message-text-outline"
# Switch Configuration Section
switch:
    switch_out_led:
      name: "Out LED Switch"
    switch_run_led:
      name: "Run LED Switch"
    switch_factory_reset:
    switch_environmental_calibration:
      name: "Sensor Calibration"
# Select Configuration Section
select:
    c4002_id: my_c4002
    operating_mode:
      options:
        - "Mode_1"
        - "Mode_2"
        - "Mode_3"
# Minimum and Maximum Detection Range Configuration
number:
    max_range:
      name: "Max detection distance"
    min_range:
      name: "Min detection distance"
    light_threshold:
      name: "Light Threshold"
    target_disappeard_delay_time:
      name: "Target Disappear Delay Time"
Reality Check: Known Limitations
While the C4002 offers powerful data, it is a 24GHz radar, not a magic wand. Here are the physical limitations you should know before buying:
  • Single Target Tracking: The sensor generally tracks the strongest signal in its field of view. If two people are walking, it will likely return the data for the one closest or moving fastest. It is not a multi-target tracking system like the $300+ commercial units.
  • Metal Interference: Like all mmWave sensors, large metal objects (fridges, metal shelving) act like mirrors for radar waves. Avoid pointing it directly at large metal surfaces to prevent ghost reflections.
  • Wall Penetration: 24GHz waves can penetrate thin drywall and glass. While "Software Range Limiting" helps, you may still detect movement from the hallway if installed on a thin door. Proper positioning is key.
How to Get Started (The Hardcore Way)
This module is built for Makers, not passive consumers. It requires a microcontroller to interpret the data.
Project Cost Breakdown:
  • DFRobot C4002 Module: $8.90
  • FireBeetle ESP32-C6 (or similar): $5.90
  • Wires & Case: ~$2.00
  • Total: ~$16.8 (Still 75% cheaper than high-end consumer radars).
Software Setup:
You don't need to reverse engineer the protocol. DFRobot provides a ready-to-use library.
Download the DFRobot_C4002 Library from GitHub.
Open the getAllResults.ino example.
Flash it to your ESP32.
Open the Serial Monitor and watch the "Matrix" of real-time data flow in.
Conclusion
If you just want a light to turn on, buy a $5 PIR sensor.
But if you want your smart home to understand context—speed, direction, and signal strength—you need raw data.
The C4002 offers a rare combination of long-range static detection (10m) and open data access at a DIY-friendly price point. It demands some coding skills, but the control it offers is worth every line of code.
[Get the C4002 Module Here]
[View the Full Wiki & Code]
