PROJECTS Arduino
Top 10 Arduino Projects
DFRobot Jun 30 2016 260644
Arduino is a hardware and software company, project, and user community that designs and manufactures computer open-source hardware, open-source software, and microcontroller-based kits for building digital devices and interactive objects that can sense and control physical devices.
The first Arduino was introduced in 2005, aiming to provide a low cost, easy way for novices and professionals to create devices that interact with their environment using sensors and actuators. Common examples of such devices intended for beginner hobbyists include simple robots, thermostats, and motion detectors.
This video shares Cool Ideas of some of Advanced arduino Projects.All these Projects are Based on arduino Microcontroller and use some basic sensors like sonar,Infrared,Force sensor,some components like servos,motors,LED's,Displays,shields etc.The arduino uno r3 is a microcontroller board based on the ATmega328. It has 14 digital input/output pins (of which 6 can be used as PWM outputs), 6 analog inputs, a 16 MHz crystal oscillator, a USB connection, a power jack, an ICSP header, and a reset button.You too can make these Amazing projects at Home.
10.Make your Own Arduino
9.Arduino Drawing Machine
8.Arduino Self Balancing Robot
7.Arduino Smart Watch
6.Arduino Spider Quadruped Robot
5.Arduino Quadcopter
4.Arduino Gesture controlled Robotic Arm
3.Arduino Rubik's cube Solver
2.Arduino 3D Printer
1.Arduino Ball and Plate PID Control
source: RZtronix
