TUTORIALS ESP32MicroPython ESP32 MicroPython Tutorial: Encoding JSON
Jul 11 2017 262519
The objective of this micropython tutorial is to explain how to encode a JSON message using MicroPython and the ujson library on the ESP32.
The objective of this post is to explain how to encode a JSON message using MicroPython and the ujson library on the ESP32. You can check how to enable the MicroPython support in this previous post. Also, if you need a guide on parsing JSON, check this previous tutorial.
The code
First of all, we need to import the ujson module, which is done with the following command:
1 import ujson
Important: at the time of writing, ujson was one of the modules included in the MicroPython firmware, so we can just import it without any additional procedure. Nevertheless, if you can’t import it out of the box, the module may no longer be included by default and need to be manually installed.
The example JSON message we will try to get is the one bellow. It is simulating a possible message from an IoT device, having a type of device (temperature sensor) and some dummy measurement values.
1 {
2 "deviceType": "Temperature",
3 "values": [23,22,25]
4 }
So, we need to put the structure of our message in a variable. We will use a Python dictionary, which works as a name-value structure. Thus, it suits well the structure of JSON.
We start by assigning an empty dictionary to a variable called dict. Then, we will assign the string “Temperature” to the key “deviceType”.
We will also assign a list with the values shown in the JSON to the key “values”. Note that a value for a Python dictionary can be an object [1], such as a list.
After the assignment, we will print the dictionary variable, just to confirm the values are correctly assigned.
1 dict = {}
2 dict["deviceType"] = "Temperature"
3 dict["values"] = [23,22,25]
4
5 print(dict)
So, after executing the previous code, we should get an output similar to figure 1. As can be seen, we have a dictionary structure with some name-value pairs. Note that the string representation of the Python dictionary is very similar of a JSON string.
Figure 1 – Content of the Python dictionary.To finalize, we will now convert the dictionary to the JSON string, by using the dumps function of the ujson module. This method receives as input the dictionary and returns its JSON string representation. After invoking this function, we will print the result.
1 encoded = ujson.dumps(dict)
2 print(encoded)
The final result can be seen bellow in figure 2, where the encoded string is printed. Note that the output is very similar to the string representation of the dictionary we got before, but the names and values are now between double quotes instead of just single ones, which is how JSON if formatted.
Figure 2 – Final output of the JSON encoding program.
He had written many useful tutorials and projects about ESP32, ESP8266, If you are interested, you could check his blog to know more.
